The attached document is my analysis of the functions of the Analog Voltage Generator Circuit K8. I built and tested the circuit so I could see what it actually did to the input wave train and see what output looks like. Report contains a describing of the card its inputs and output. The tests I conducted are documented with description of what I did and includes scopes shots of the signal going through the circuit. While circuit is not real complex by building it I could see the effect of the bias resistors as their setting define what really is going on with signal.
One thing that is apparent after doing that is voltage level is not being used to control gas required from accelerator input as that information would have been removed by the first amplifier in circuit as it puts out a 5 volt pulse. Frequency appears to be set by Variable Frequency Generator that leaves pulse width, which testing of the card shows to be past through with no changes. As source of signal is Digital Means card I did take a look at it and near the output of that card is an SN122N and one of the functions of this chip is vary pulse width which Stan has stated can be used to control gas production.
Main function of this card seems to be take an input pulse train at 5 volts PTP and output the same wave train with approximately 1 volt PTP with a DC offset. Offset is always 2 volts (required to not clip signal) but can be set higher to set a minimum idle speed. See analysis and test results for more detail.
If you are just reading this I have posted an update version of the test report it has K8 in title. I had missed an important function of the circuit as I did not have a variable width pulse source when I did initial testing. The variable width pulse causes the voltage to rise. I did not see this happen with a square wave source. Update has addition test results that show this effect and additional information on how to sync pulse.
