does resistance in a transformer transfer into flux?
Belfior
« on May 13th, 2019, 12:18 PM »
If my primary coil in a ferrite core transformer has high impedance, does this actually mean that I need to push a lot of power into that coil and that in turn transfers into a lot of flux inside the core?
Just trying to think out of the box on how to maximize the gain I get in L2
So longer L1, smaller gauge, bigger circumference and loop spacing gives me more impedance right?
Will I do better with high freq and air core?
Re: does resistance in a transformer transfer into flux?
« Reply #1, on May 13th, 2019, 01:08 PM »
Ohmic resistance turns into heat, nothing else.
When you say impedance, would that be the resulting impedance at a given frequency, including the inductive reactive resistance in the calculation?
Belfior
« Reply #2, on May 14th, 2019, 01:37 PM »
Quote from Lynx on May 13th, 2019, 01:08 PM
Yes. Anything to make it harder for the current to pass through the coil and when the supply has to push more current in, that would result in more flux inside the core. Multilayer coil also works just fine
patrick1
« Reply #3, on May 15th, 2019, 07:22 AM »
also the permeability of the core, - and note the random iron filings i coughed up onto transformer.
and yes resistance is bad.  i should use less of it. - but perversely transistors like it.
« Reply #4, on May 15th, 2019, 08:59 AM »
Quote from Belfior on May 14th, 2019, 01:37 PM
As for inductive loads (coils/ballasts, motors, etc) one way to make it harder for the current to pass through the coil would be to up the frequency.
so when the supply has to push more current in, besides lowering the frequency, upping the voltage would also work, perhaps even a healthy mix between the two?
« Reply #7, on May 22nd, 2019, 05:35 AM »
Seems I asked a similar question once before...
I posed that if you have an inductor of 10 ohms resistance would this inductor behave differently than another inductor that has only 1 ohm resistance connected in series with a 9 ohm resistor.  The assumption is that the number of turns for each inductor is identical.
To me there is a consideration of distributed resistance at play here.  I tied to prove this to myself using some Nichrome wire, but the results were inconclusive.
