We know we can use the
H bridge as Gate but can we back switch the electron extract this is important to achieve now
we are on this topic.
NOTES
a)
Max had Optos on the 9xa
b)
Mike Made 9xa opto mosfets as gate and also mosfets in a totem pole arrangemen to drive 2n3055 or IRFP260N etc t
https://youtu.be/cmMURk12akgc)
Valentin Petkov /valyonpz/ uses totem pole and show solid relay using in some cases as gate
(remember inverter on signal)
https://youtu.be/namRpMcrd84 ========================================
My Invitation and comment is Can we confirm
the H bridge can be the Gate and the electron extract ( using h bridge forward reverse logic)?
What Timing controls can be on it ? Gate vs pulses to keep ratio but accelerate repetitions
NAV NOTESset the gate as follows:-
The duty cycle of the gate needs to be at 90% in favor of 'on' and 10% in favor of 'off'. BUT...the entire length of the gate time on and off must be three seconds exact. This is the error of our ways.
Can we keep ration but accelerate the repetitions to as fasts as possible?
1 can advanced the boards above
we draw up a specific H bridge totem daughter board with ration adjust or speed adjust of reptitions and post it here
So to control gate fast silicon mosfets (to Nav ration 90/10) and also switch back the electron extract to 9xd during gate off ?
to make usable voltage.
The faster we do the gates and switch back to electron extract caps better the result if ratio keep ism y feeling
If we keep Ratio 90 on 10 off we can in fact increase speed and stay true to the forumla?
We know there are high performance results on to electrons and atoms ionization
with fast pulse and gate best is picosecond rates.
to use such we would jump specifically of 9xa/9xb and have inverted signal
so we can jump 9XA and use like Mike did above and have invert signal to stay tru to the meyers
All comments welcome as this is a great topic on locking
in a daughter board every one can trust and use
PS from Deep study of pulsing red leds the best ionization rate at low wattage into water spiting = best results are in picosecond
do this driver could also be added to the 9xd and run leds in fast rate
Daniel
