So While we look and Adjust that last post above together Nav
We Are Specifically Discussing Pulse Train number of pulses and Gate Timing ratio in this H bridge Thread ,
Using 9xa into a daughter board vic/ normally transistor but we swap for fast h bridge so we can use h bridge logic to back switch electrons during the tau we set. triggers from the 9xa 5 khz with over layed 5 khz gate , h bridge alows pwn in and allows dc voltage in from variac /booster circuit or series vics
Pulse number and Gating timing in TAU
to find a ratio that you and I know can be set as perfect ratio. starting at what ever voltage amplitude and scaling voltage amplitude later whilst keeping ratio ,
( as noted previous about gradual voltage amplitude rise to allow pll to work and not freak out)
once running this ratio
Purposely not discussing the voltage amplitude or the ringing or step charge leave out of conversation please for now.
AS I am Trying to Focus on the H bridge and timing to remove electrons whilst hitting
the number you want or have studied from AP and Stan to allow fastest gating scaling whilst
in ration as possible for testing..
Focus is the Pulse train vs gate time tau Ratio.
Please suggest and spec
a Specific number pulses (a number or measurement ) in pulse train to GATE Ratio based on your 3 secs gate
How many pulse to TUA
NAV PLEASE SET THIS
Ratio
5 HKZ ( 2500 discrete pulses ) to 5 khz ?/TUA 0.333hz is 3 seconds over layed GATE ?
Please Set this now NAV
NAV PLEASE SET THIS
Ratio
