Ok, I did a LPM test with my other cell a month or so back and dug that figgers up.....running at 9v, 0.66mA and got 375ml p/m....hope you can do something with that info for now....... I also build a flashback flame burner for the cell and already burned a flame of the gass (ofcourse with lots of bublers and normal flashbacks for safety)......the flame heat adjustment is not to easy and so far I can asume the ports/nozle holes is verry tricky and will be verry small..........as soon as I'm sure "all is ok" I'll re-collect my stuff and continue.....
I might be going way out now............but do you think that we can split water with a sound at the same freaquancy as that used in the electronics or even a laser like what meyer tried or probably almost got right....... I can't mesure my electronic's freaquancy yet and the resisters and caps on the circuit does not give me what they calculte to.......well let me (in time) mesure it before I say that for sure......... O' this cell has a 0.67mm clearance for the water to pass through
I have a gut feeling it's the cavitation aspect many of us have been overlooking. Once we get that added to the formula, then I think we will start seeing a flurry of good results.
Now on to your measurements. We are looking for 140 Watts per LpM or smaller. Let's see what we got here:
9 Volts at 0.000660 Amps is: 0.00594 Watts. Now I'm going to go out on a limb and assume you didn't mean 0.660 mA and instead meant 0.660 Amps or 660 mA. That would give us:
9 Volts at 0.660 Amps or: 5.94 Watts
375 mL per Minute is: 0.375 Liters per Minute (which means it should have taken 160 Seconds to fill a 1 Liter bottle.)
Performance then is: 5.94 / 0.375 or 15.84 Watts per LpM (
Which is Outstanding)
Giving you a C.O.P. of 140 / 15.84 =
8.838 Over Unity.
Seriously now, if those numbers are accurate or even in the ballpark, the next step is absolute complete documentation of what you built. I know it sucks and isn't nearly as fun as building and playing with your prototype, but we all need to try our hand at replicating what you did to see if it's a fluke or if you have really mastered the so-called Stan Meyer Effect.
