It is my understanding of a gyroscope, once spun-up and set into a position, it will tend to remain in that position for as long as the flywheel remains spinning. This assumes the flywheel itself is not anchored, i.e. has a two-axis gimbal support.
So my question: With all the fancy pulse motors that have been built over the years, has anyone constructed a balanced powered flywheel motor and mounted it on a two-axis gimbal? Then have they let this motor run over a 24 hour period?
I ask this question because something occurred to me. If the Earth rotates one complete revolution in a 24 hour period, wouldn't it make sense that a powered gyroscope also display this same rotation or change in attitude over the same 24 hour period? Couldn't the angle of the gyroscope as compared to the direction of gravity be used as a clock?
It's my assumption a basic gyroscope doesn't lock into the direction of gravity. Instead it attempts to hold its vector as an absolute, regardless of what all other objects in space are doing.
If anyone knows some or all of the answers to my questions above, please respond. To me this is one of those things in life that should be obvious, but when you really dig into it, doesn't seem so obvious anymore.
Here's a little video for reference:
https://www.youtube.com/watch?v=JnKloSdUJLo
