If this dont get your stomach cringe... There is something wrong with you..
https://youtu.be/CrJIzrmX1mI
I have spent the last 2 or so months working on new ideas ( new to me) and looking for answers. looking at and making my own theory's about the way things work. or look to find others who's make sense.
In the process I agree that I need a device that runs on pure potential. something that can also generate a massive magnetic field. i want that BEMF... that current and high voltage...
How can i do that? Well it appears Joseph's motor may do just that.
still no one can answer what happens when a really long wire is shorted across a battery and released before the current gets through it back to the source, do yo pay for that? is there losses? is there a magnetic field? etc.
so i ask a other unanswerable question.
if I have 1000Lb of copper,lets say its fine wire ( say 36 awg) , can i generate a magnetic field that is just as strong with just voltage ( minimal amperage)
where as i was doing it with 1 awg but the same 1000Lb of copper. this yields massive BEMF.
the 1AWG generated the same or smaller magnetic field before the current made it through the wire, but this requires ultra fast switching and possibly high current. we know lower the resistance the less the loss.
so can i go the other way? massive voltage and almost no current? can I generate a magnetic field that is = to or greater than that of the same mass of wire but with just potential? and in doing this we dont need the fast switching to get the same effect... we can almost do it with out thinking about it... current cant get through that mass of small wire... but POTENTIAL CAN
i will be reading the book of Newman, to rediscover what he did, and see f it fits our current understanding that " the load dose not consume the energy" ( i think it dose according to what i have seen already)
but instead of using current ( that kills our dipole) we use potential. " high tension" so we can keep our dipole.
ok, so i want to build it big... no less than 40 lb of magnet wire... more like 150 if i can get it...
E=MC2
if Energy is = to Mass x Light 2... well then the bigger we make it, the more energy we can generate. ??? the more potential it has...
i came to the conclusion over the last 2 months or so that the bigger we build something, the more potential it has to show us something....
a small 12V battery connected to a large inductor ( like a large 500 foot spool of #8 wire) can do amazing things. What if we multiplied everything by 100,000?
you think 12,000,000 volts will yield different results? or is it the same old stuff? what about instead of 500Ft we use 500,000,000Ft?
any how "go big or go home" i think should be Joe's new Quote...
The more mass he states, the more energy it can generate, and the less input is required... I guess nature can agree with that...
we must not think so "localized" me thinks...
He Quotes "mass in to energy using a 100% conversion process"
I'm not sure about all his deep thoughts at the moment... but in due time i want to see if his theory makes sense to me with what i have already learned.
feel free to fallow along...
ps, i have a play lost of the videos i found usfull about Joe, and ill keep adding to it.
https://www.youtube.com/playlist?list=PLsiIKXpZfLKLAU9vA2ZkdmCC2CuKadDUt
E=MC2
