Common mode chokes see here:-
https://www.coilws.com/index.php?main_page=page&id=128
It is very interesting that you cannot overload a common mode choke even with 200 amps or more. There design is to trap unwanted currents travelling in circuitry by the use of two inductors and capacitors which are put to ground.
In my schematic you will see that normal ac current goes through the inductors and into the load in two directions as per a normal ac circuit. Common mode currents however travel in the same direction down both conductors and this energy loads both L1 and L2 simultaneously. This traps any common mode currents in the circuit. When the ac changes direction or stops, the two coils offload their collected common mode currents into the caps which in tern discharge it to ground. It is interesting to note that the chokes that collect common mode current are designed to be self resonant at the frequency or an harmonic of the common mode current frequency. Isn't that interesting?
What if Stans network is laced with common mode current and replicates a common mode choke but instead of putting it to ground he collects the energy in the caps? You can then see why he would add the diode because the diode would forward bias the inductor output after they collapse. Isn't that interesting? See lower drawing.
So in essence you could have a forward biased circuit where you could use a very small load in its normal current phase and operation, allows lots and lots of common mode currents to be trapped in resonant chokes which discharge into caps. Sound familiar?
Just saying.
Just saying.
