https://www.youtube.com/watch?v=SDbUDO_0ou4#ws
http://cluesforum.info/viewtopic.php?p=2393699#p2393699
https://www.youtube.com/user/sumstuff52/videos
https://www.youtube.com/watch?v=UVreRYDcPHE#ws
dedicated thread to WTF and unimaginable stuff...
All we can do is to keep after it. The truth will come out and all the bad ideas will fade away. What is left is what we really want anyway.
knowing what we have learned about centers of mass i make a case for earth tides...
crazy as it seems, but much easier to explain. if it be that the earth oscillation is of a flat earth, and is more like a spring from left to right every 6 hour technically could cause low and high tides, due to mass moving from side to side rather then circular.
thoughts?
I myself believe in the expanding earth due to induction. but never was able to deal with the tides.
I am open to theory, so ill try to see what questions i can answer.
If i spin earth, and its perfectly round, and also perfectly weight distributed would there be a low and high tide still, if we take away the moon.. i say the moon mass is not really high enough, or close enough to be included in this equation.
i simply say if the earth was spinning, and was perfectly round, and spins at constant velocity, would a tide be caused by spin alone?
now i say it is true the earth is not round, or perfect balanced. there also will be a change in velocity as it rotates, will it now give a high and low tide at 6 hour intervals? the earth center of mass must be changing true or false?
as an example i now have a boat, and fill the water at one side only, and the boat is only able to rock back and forth due to filling of the ocean or boat with a single water source. will it now simply rock back and forth forever with a frictionless water?
what new wonder do you have?
Я начинаю понимать сообщение АФФА, не то, что кто-то заботится.
Time as a field function is NOT the same function as registered by our clocks, which record the changing entropy of a system, but is the function which makes this happen.
There is only ONE reality in our universe, and that is the concept of SPIN, and from this derive twelve dimensions. Twelve dimensions are necessary and sufficient to express our universe in its entirety.
Dimensions must include, as well as their vector direction, the component of reality in that direction for without the reality there would be no dimension.
Dimensions are arranged in four fabrics of three each, linked by a "quadrature concept". This is the structure that Relativity strives for by introducing the [square root of -2] between the space and time axis.
The concept of force is a fiction which we invented to stultify our thinking. It is merely a coverup for our lack of understanding of the interaction of reality.
please give references, and material, and what your conclusions are. or a summery of how this effects m e in the world of pots and pan..
The Universe contains no anomalies, and the appearance of an anomaly is warning that our understanding is inadequate.
All scientists/professors/researchers should read this quote.
O:-) O:-)knowing what we have learned about centers of mass i make a case for earth tides...
thoughts?
i answered my own questions. in this case. ...
it should be noted i asked a question u failed to answer.
