A Can Of Worms..
Re: A Can Of Worms..
« Reply #25, on March 16th, 2015, 04:30 PM »
Quote from firepinto on March 16th, 2015, 03:06 PM
I'm really not interested.
to be noted sell out.. no need to be a part of the forum if you don't have anything to add.  pretty funny?
« Reply #26, on March 16th, 2015, 04:34 PM »
Quote from firepinto on March 16th, 2015, 01:02 PM
Maybe you should post your booklet in the for sale section.  http://open-source-energy.org/?category=58
- Efficient & Renewable Energy Production Research
    Home
    Login
    Register
    Off Topic
    Off Topic
    A Can Of Worms..
« The Corporation
A Can Of Worms..
abstract logic riddle »
    Print
Pages: 1  Go Down
    Hero Member
A Can Of Worms..
« 7 days ago »Last edited 6 days ago
http://cluesforum.info/viewtopic.php?p=2393699#p2393699
https://www.youtube.com/user/sumstuff52/videos
dedicated thread to  WTF  and unimaginable stuff...
« Reply #1 7 days ago »
I had thought come on really? A glass sky, then i remembered if that is so how can a meteorite hit earth?
then i remembered the fact that there is 2 giant holes right above the Bermuda triangle in our magnetosphere causing ozone to leak away from Earth.
then i said if an asteroid hit the earth, and it was indeed glass, and if it smashed through the glass and destroyed all life then could it really be a possibility that that is the reason for these holes?
so there is one giant asteroid hit right around the gulf of Mexico.  could that strike been the cause for the hole in the firmament?
now i say holy cow.!   So i also remembered a star trek episode of the people on a asteroid they had thought was there home planet, but in the episode Kirk, and spok had to recalibrate the course of said planet because it was on a direct course with another planet..
Hmm this is getting good....
« Reply #2 7 days ago »
open source,
« Reply #3 3 days ago »Last edited 3 days ago
really 30 views?  do we only have 5 members?
now i say what is
edl
adelphi, means brotherhood.
lol i already new ed lee had information given to him.  the funny thing now we all know!!
:heart: https://www.youtube.com/user/freethisone?feature=mhum
    Administrator
« Reply #4 3 days ago »
All we can do is to keep after it.  The truth will come out and all the bad ideas will fade away.  What is left is what we really want anyway.
    Hero Member
« Reply #5 3 days ago »Last edited 3 days ago
Quote from Matt Watts on March 13th, 01:42 PM
well here is some good proof i guess?
http://www.lhup.edu/~dsimanek/hollow/palmer.htm
and not to mention how do the magnets spin ontop of the globe lol
http://en.wikipedia.org/wiki/Ley_line
« Reply #6 3 days ago »Last edited 3 days ago
knowing what we have learned about centers of mass i make a case for earth tides...
crazy as it seems, but much easier to explain. if it be that  the earth oscillation is  of a flat earth, and is more like a spring from left to right every 6 hour technically could cause low and high tides, due to mass moving from side to side rather then circular.
thoughts?
I myself believe in the expanding earth due to induction. but never was able to deal with the tides.
I am open to theory, so ill try to see what questions i can answer.
If i spin earth, and its perfectly round, and also perfectly weight distributed  would there be a low and high tide still, if we take away the moon.. i say the moon mass is not really high enough, or close enough to be included in this equation.
i simply say if the earth was spinning, and was perfectly round, and spins at constant velocity, would a tide be caused by spin alone?
now i say it is true the earth is not round, or perfect balanced. there also will be a change in velocity as it rotates, will it now give a high and low tide at 6 hour intervals?  the earth center of mass must be changing true or false?
as an example i now have a boat, and fill the water at one side only, and the boat is only able to rock back and forth due to filling of the ocean or boat with a single water source.  will it now simply rock back and forth forever with a frictionless water?
« Reply #7 2 days ago »Last edited 2 days ago
Quote from freethisone on March 13th, 03:32 PM
    thoughts?
answer my questions..
now i relate what is learned from earthquake progression to my ice age model. i should be getting all the credit in the world because i am presenting them..
i am only here to solve these problems we all face..
earthquake progression due to a spinning earth is caused by induction.   friction and heat due to eddy currents heat the liquid parts of the earth due to pressure. Simply splitting, like a water balloon... and efectual forces are observed.
this pressure is now described in a 3 d version like no one before has mentioned.
It relates to inductions, or pressure, it imitates the laws of motion. there are inductive forces at work. EX _ PO star K is formula for euclidean geometry and so on.  the axiom is true as i will continue..
what new wonder do you have?
A problem in dynamics by james clerk maxwell describes. in our reality we observe these forces. and so on....
    Administrator
« Reply #8 42 hours ago »Last edited 42 hours ago
Quote from freethisone on March 14th, 10:32 AM
Я начинаю понимать сообщение АФФА, не то, что кто-то заботится.
    Hero Member
« Reply #9 42 hours ago »
Quote from Matt Watts on March 14th, 10:06 PM
sorry i dont speek freeky deeky dutch please explain?
    Administrator
« Reply #10 41 hours ago »
Quote from W.B. Smith
    Time as a field function is NOT the same function as registered by our clocks, which record the changing entropy of a system, but is the function which makes this happen.
    There is only ONE reality in our universe, and that is the concept of SPIN, and from this derive twelve dimensions. Twelve dimensions are necessary and sufficient to express our universe in its entirety.
    Dimensions must include, as well as their vector direction, the component of reality in that direction for without the reality there would be no dimension.
    Dimensions are arranged in four fabrics of three each, linked by a "quadrature concept". This is the structure that Relativity strives for by introducing the [square root of -2] between the space and time axis.
    The concept of force is a fiction which we invented to stultify our thinking. It is merely a coverup for our lack of understanding of the interaction of reality.
    Hero Member
« Reply #11 40 hours ago »
you have presented a new wonder, and i will answer the question..
truth is i knot grasp all i need to know  in order to understand your 12 dimensional space..
please  give references, and material, and what your conclusions are. or a summery of how this effects m e in the world of pots and pan..
 ty Matt.
    Administrator
« Reply #12 31 hours ago »Last edited 31 hours ago
Quote from freethisone on March 15th, 12:22 AM
http://www.rexresearch.com/smith/newsci.htm
My conclusion is that Mr. Smith has given us THE formula for how everything works.  It's the same formula that visitors from other worlds use to create spacecraft capable of travel among the stars.  If we come to understand this formula, our boundaries are greatly increased or removed completely.
But you still have a choice to ignore it and go your own direction; you wouldn't be the first one to do so.  In fact, you may actually embrace your own "pots and pans" limitations.  Many feel secure being a slave to the self imposed cage that surrounds them.
    Global Moderator
« Reply #13 29 hours ago »
    The Universe contains no anomalies, and the appearance of an anomaly is warning that our understanding is inadequate.
Love it.
All scientists/professors/researchers should read this quote.
And then some.
Thanks for the link Matt, gonna check it out :thumbsup:
    Hero Member
« Reply #14 25 hours ago »
no 1 will ever now the 12 universe.
but i have solved it for sweet 16
it is this way, now i say is the world under power, i propose a way to alter earth course by use of closing the exhaust port of a thruster.. how i do this?
i put a pyramid over it..
the last 2 sentences i will be work out in due time.
. solving for phi was not difficult.. and sweet 16...
    Administrator
« Reply #15 24 hours ago »
Quote from Lynx on March 15th, 11:39 AM
That was the one I used with Russ.  An anomaly is a bad thing, not a good thing.  And here we are searching for them hoping to find a clue how to create free energy.
I recommend getting your hands on everything Smith wrote and thinking seriously about it.  And while you are at it, look at Professor William Hooper's work too.
    Hero Member
« Reply #16 23 hours ago »
this is how i show shew first in your heart. in all of the lands, across the time only a few men are ever remembered.
and i quote this i say led to the desegregation of achievement, and wonder, because the hundreds of billions before intended everyone to advance together. and pick out of the crowd the men who did it best.  with so little few that even consider to wonders or the hatred of civilization as benevolence are the seekers of truth and the magicians who preach the best likes. they will never find it. they have stagnated our lives in such a way that men and women like you who live to invent would be left simply to wonder and to roam with no direction to follow..
its a vector quantity...
O:-) O:-)
« Reply #17 23 hours ago »
    thoughts?
i answered my own questions. in this case. and have certain wonders contained
knowing what was learned...
    Global Moderator
« Reply #18 4 hours ago »
Quote from freethisone on March 15th, 05:38 PM
    i answered my own questions. in this case. ...
Really?  I didn't see anything that looked like answers.  The flashy colors probably distracted me.
Woe to those who call evil good and good evil, who put darkness for light and light for darkness, who put bitter for sweet  and sweet for bitter.  Woe to those who are wise in their own eyes and clever in their own sight.
   Isaiah 5:20-21
http://twitter.com/firepinto  www.firepinto.com
    Hero Member
« Reply #19 4 hours ago »
ill tell you in my little booklet called the tetra gram... it is a sweet 16 subject cost of only 15 dollars. or simply  learn what principles of science to apply.
    Global Moderator
« Reply #20 3 hours ago »
   Isaiah 5:20-21
    Hero Member
« Reply #21 2 hours ago »
tell me firepinto what do i need to include in my booklet that tell u you got your moneys worth?
would it be easier for me to show u for free> or what?
your bug on a monkeys back..
    Global Moderator
« Reply #22 119 minutes ago »
From what I thought I read in your post, you already had a booklet written that you were selling.  I really don't know if I'll ever understand what your saying.
   Isaiah 5:20-21
    Hero Member
« Reply #23 102 minutes ago »Last edited 97 minutes ago
2 feet firmly placed on the table...
in fact i have several booklets, it should be noted i asked a question u failed to answer.
i would like for the person to get what they asked for..
put together a list of questions, and ill make a limited edition booklet  for whatever subject fits you best.
vapor
magnetic s, and the rediscovery of ex-po star K torque  precession on a wheel. and my own invention. the perpetual dynamo that generates energy without a physical net force.
as a free  bonus
precession, and so on. corral castle  motors... and include a extra work free.
i already explained all the principle in the forum
. and be amazed at its works.
i am a true horsemen.
    Global Moderator
« Reply #24 80 minutes ago »
Quote from freethisone Today at 02:43 PM
   Isaiah 5:20-21
    Print
Pages: 1  Go Up
« The Corporation
    Off Topic
    Off Topic
    A Can Of Worms..
Hello, Guest!
Please login or register.
Forever
Login with username, password and session length
Topic statistics Topic statistics
Users OnlineWho's Online
0 Members and 1 Guest are viewing this topic.
Quick access
=> Select destination
Latest Posts Feed
This topic:
    posts
This forum:
    posts / topics
All:
    posts / topics
    Powered by
Quote from firepinto on March 16th, 2015, 12:26 PM
i supposed you deny posting to a thread u had no interest in?
