Maybe Allegheny Ludlum knows of a jobbing distributor. If this is for a prototype that will involve quantity they might send you a sample.
GOES - Grain-Oriented Electrical Steel - Allegheny Ludlum Products
BTW, I didn't know and was curious about what this stuff is. Apparently, it's steel normally rolled into sheets that has properties that make it good for use in laminated transformer coils, etc. For anyone that is interested, from Wiki:
"Electrical steel is an iron alloy which may have from zero to 6.5% silicon (Si:5Fe). Silicon significantly increases the electrical resistivity of the steel, which decreases the induced eddy currents and thus reduces the core loss. Manganese and aluminum can be added up to 0.5%.
Increasing the amount of silicon inhibits eddy currents and narrows the hysteresis loop of the material, thus lowering the core losses. However, the grain structure hardens and embrittles the metal, which adversely affects the workability of the material, especially when rolling it.
There are two main types of electrical steel: grain-oriented and non-oriented.
Grain-oriented electrical steel usually has a silicon level of 3% (Si:11Fe). It is processed in such a way that the optimum properties are developed in the rolling direction, due to a tight control (proposed by Norman P. Goss) of the crystal orientation relative to the sheet. Due to the special orientation, the magnetic flux density is increased by 30% in the coil rolling direction, although its magnetic saturation is decreased by 5%. It is used for the cores of high-efficiency transformers, electric motor and generators.
Non-oriented electrical steel usually has a silicon level of 2 to 3.5% and has similar magnetic properties in all directions, which makes it isotropic. It is less expensive and is used in applications where the direction of magnetic flux is changing, such as electric motors and generators. It is also used when efficiency is less important or when there is insufficient space to correctly orient components to take advantage of the anisotropic properties of grain-oriented electrical steel."
What do you think? Thanks, Scot
