Can't seem to buy distilled water here any longer. I've heard that deminerslised water is fine.
Yeah, it's one of those things we all have to deal with as what ever we use the missing resistance from the water must be made up in the chokes or secondary, still working on that. So, if you use the 8xa circuit then try making the chokes using resistance wire and compare the differences. Also it really helps to have a cell all wired up in series like the ones I sell or others like it that can be found in the internet. If you make your own build it as best you can to have each cell exactly the same for think about it this way, how large is a single water molecule?
For me I went from the 8xa circuit right into the voltage intensifier circuit transformer and I used distilled water for it has a high resistance and cuts the load seen by the secondary side of the transformer. The water that you have to use is what you have to work with so keep the thought in mind that you have lost resistance in the form of water so you must make up that lost resistance someplace else in the circuit by adding in some resistance. It's tricky and the material cost goes way up but that is what we have to do in order to reach the ionization threshold for the atoms or I guess it's better to say exciting the electrons to the point where they are easy to take away from the atoms or even be ejected by the atoms to break the bonds of the water molecules. The problem with water is it's resistance is temperature dependent so the way I see it we have to build a system that can control the temperature to a where it works best from our observations of the experiments we preform.
If one is unwilling to build or test anything then they really should just sit back and enjoy the show as they are not going to help those that are actually performing experiments for the information that those that are doing the work gain will be something they simply can't understand. Haipu it is simple if demineralized water is all you can get then that is what you have to work with so make the best of it through understanding that this is a impedance matched circuit but the parameters of the circuit are variable with the changes in temperature, metals, salts, and acids in the water, and understanding that some of these will build up in the water as more and more water is broken down for they will not go with the gases. We can do this but much care must be taken towards understanding the many different dynamics of a system such as this.
If you need to get some equipment then get it, if you need to buy something then buy it, if you need to build something then build it as there simply isn't any other way to go about solving this technology if something is missing that can aid your work in gathering all the information you can from your experiments. We can do this but we must be willing to spend some money, and do the work, or support those that are doing the work and stay out of their way and let them work with the support given.
Now a lot of what I said isn't aimed at you Haipu but to a lot of members on this site be them moderators or not. The science given by me and a few others is correct and will allow each and everyone of us to surpass the results that Meyer had gotten but you must do the work. I will not do it for you nor will most of the others as we simply can't afford to be building items and giving them away free of cost. I have been working at this since 2006 and in this time I have learned things the hard way by making use of the scientific method which is a nice way of asking and answering questions that gives results when followed if results are to be had for it will also show if something will not work.
People often don't know how to handle a person such as I am for I have done so many experiments that I really have left everyone far far behind from following the scientific method for all of these years. The soft form of suppression that I talk about sometimes is real and it is prevalent on just about all the forms and mostly it consist of someone doing nothing but thinking wanting their voice to trump those that are actually doing the work and talking about the results they are seeing and/or findings they are observing from their experiments. If you want an example of this you need look no further than the thread where secursupplies posted the interview of me taking at the Global BEM at the replies that followed. All talking about everything but what was being shown in real time for the very first time ever which was someone showing high voltages being applied to a water fuel capacitor while restricting the flow of amps. They wanted their voices to trump what was being shown in the video and if you read it is does make for some interesting reading but it does nothing to advance this technology as it is more or less a form of entertainment as best.
Now this thread hits right at the heart of what has been missing in a lot of peoples work in that water is a physical part of the voltage intensifier circuit (VIC) something that Meyer calls "Re." As you have seen water is dynamic in that it's resistance changes with respect to it's temperature, contaminates solvated in it, and metals leached out from the materials being used into it. The VIC is a complete isolated circuit that has this variable water as a part of it that we must all learn the hard way on just how to deal with it.
Now all of these equations start to mean something for the VIC is a complete circuit. Water's role is that of resistance for the most part but it also plays other roles in that it will align with electric field and it can take on a charge, plus has the ability to act as a dielectric liquid. But there is more as recent studies have shown it also has the ability to separate electrons and ions creating what is now being called and exclusion zone.
Water is an amazing substance as not only can it allow life on this planet to be great it can also sustain our way of life, cleanly, cheaply, and is in abundance on the surface of the earth that we may make use of it easily. All that has been posted on this site by me and a few others should allow anyone to make use of water as a source of fuel, but you are going to have to do the work, and foot the bill for your work. You are going to fail but each time that you do you learn something from it that helps you understand more about what you are wanting to do. It's the true of our nature we learn by failing as I am sure that none of us just got up and started walking perfectly the first time around as we failed many times but we learned from our mistakes and kept at it until we got it right. Learning this technology is no different as you will fail but each time that you do you can learn from it if you kept at it and eventually you will get it right.
I hope these points are well taken,
Edward
