In my continuing studies of Stans work, I keep coming back to thought I have. Stans claims to use his VIC circuit to restrict amps and allow voltage to rise and perform the work of pulling the water molecule apart.
Now we all know that Stans circuit relies on LC resonance to create the high voltage. At LC resonance we get the greatest voltage with the least amount of current flow. We also know his circuit was designed to lock into resonance, which it did.
OK now for my thoughts about an Amp Restriction Circuit. This question is for the electronics experts out there.
Is it possible to make a simple circuit that could sense amp flow? What I'm thinking is, if we could put a electronic component in the input line going to the cell, that could sense the flow of amps, we could use that to trigger the circuit to turn off when we hit a max current. Then when current stops flowing or is reduced to a minimum amount, it would turn the circuit back on. It would then become a self resonant cycle all by itself. Now we could be turning on and off just straight DC power or a frequency generator set at a given frequency. It could actually become the gate signal.
Now doesn't this make sense to some? By turning off the power to the cell, we would be able to keep amps from flowing, and in return may even give us a voltage rise. I think we could still use the VIC coil pack with chokes, or we may not even need the chokes, but maybe just an off the shelf step up transformer from a DC powered neon sign would give us a high voltage source.
To me it makes sense, and that it should work. The sensing circuit could have a pot to adjust the current we would use to trigger the circuit. I mean it would allow us to raise or lower how much current we would allow the cell to pull before turning it off.
So what do you all think? Feed back is welcome on the general idea.
Don
Don
