Dyno, I'm convinced that time is the critical factor.
I agree fully[/quote]Consider this: The electric field (the voltage) travels at the speed of light. Electrons by comparison travel at a snails pace.
Drift velocity of electrons (basically the speed they move under the influence of an electric field) is actually very slow. It depends on the conductor, its dimensions and the applied voltage, but generally a few amps of DC will only see electrons moving a few centimetres a minute. But here's the thing, a good conductor like copper has free electrons, and indeed can be thought of as a tube of touching ball bearings. Push one ball bearing in one end of the tube, and a ball bearing instantly pops out the other end. Hence although the drift velocity of individual electrons is slow, the overall effect of current flow still appears to be pretty instantaneous.[/quote]I follow you[/quote]The same however cannot be said about ions in water. The ions are massive in comparison to electrons and can only move at a fraction of the speed of an electron under the influence of an electric field. They also have to negotiate a path between very mobile and active water molecules.[/quote]Still with you[/quote]As you say, the water in the cell, may well pull the voltage down, but even if the water is relatively low resistance, this will not happen immediately. As already stated, the OH- ions are massive in comparison to electrons and will react relatively sluggishly. This means that you can in theory pulse 12kv to the cell and as this creates an electric field that travels at the speed of light, if the pulse is short enough, then it will be back off before any current starts to flow within the cell.[/quote]I can see that as well happening[/quote]But what does this provide you with? Where does this get us?
Well, if the water molecule was pulled apart conveniently into oxygen and hydrogen, then that would be the end of it. Job done! However what Meyer depicts as the water molecule being pulled apart and electrons flying off everywhere is sheer fantasy.[/quote]It just may not have been proven yet[/quote]We know that electric field fluctuations will cause the water molecule to ionise, but this in itself does not create or produce any gas, all we get is ions that will quickly reform into the water molecule if left to their own devices.[/quote]Just look at Ed's experiment to see that[/quote]All of this then brings me back to my old argument: If you intend to pull the water molecule apart as Meyer depicts, with voltage alone, then why even have the electrodes in actual contact with the water? If the electrodes are fully insulated, with water residing in between, then you can apply all the high voltage pulsing you wish with absolutely no current flow. If voltage alone could really produce gas, then this would be the obvious, logical and simplest way to do it.
Meyer does not do this so clearly it is not all about voltage alone doing the work as he claims. And surely everyone must realise this by now.[/quote]That was one of my very first ideas. Tried a very simple test to see if it would work. Didn't, but then I never tried any high voltages over 1kv. Just 12 volts.[/quote]This is why I suggested in my thread that an Electric Double Layer is formed at the boundary of the electrodes and the water, and that high voltage, short pulses will allow electrons to breach this boundary and react directly with water molecules and existing ions, WITHOUT any current actually travelling through the cell itself.[/quote]I looked at your project, any thing promising?
Don
