Until it's proven working any theory goes.
Even smearing banana poo on the cells, it could just be the secret sauce here you know.
I know one thing to look for, very high resistance when the plates come in contact with water. The next big thing is to put some high voltage across those plates and show me bubbles. I see that by more than one person on this forum and I'll be packing up my cells to be shipped somewhere for professional electropolishing.
In order to get an idea about how a dielectric layer on aluminium would look like, I opened up an electrolytic capacitor of 33 uF / 30+ V. You can see what it looks like in the attached picture.
The aluminum foils are light-grey, so it is visible that some layer is present on the foil. As you can see, the layer can be easily scratched with a knife, and then the shining metal underneath becomes visible.
I tried to measure the resistance of the layer, which is not easy. Most of the time I measured a resistance in the order of 10 Ohms, which was also the resistance of the aluminum itself. However, sometimes when I tried to connect the probes very gently, the resistance appeared to vary between something like 500 Ohms and 2 k. However, these are not reliable measurements, indications at best.
It could be a good idea to measure the resistance as a function of the voltage applied to the layer using metal contacts applied gently to the surface, for example using a known resistor in series with a adjustable power supply and then measure the voltage over the resistor and over the layer contacts.
That way, we should see an area up to a certain voltage, whereby we see resistive behavior and above that voltage, the dielectric layer breaks down and it behaves like a shortcut.
The higher this breakdown voltage, the thicker the layer and thus the better it is.
I would guesstimate the breakdown voltage of a layer grown by a professionally performed polishing process to lie somewhere between 1 and 10V.
Here, http://open-source-energy.org/?tid=1386&pid=17650#pid17650Quote from Jeff Nading on September 21st, 2013, 06:14 AM What I would like to do is take my cell apart and electropolish the tubes myself, so what is needed, is a formula and/or procedure for an individual to do this on his own. I for one don't want to pay someone else to do something I think we ourselves can do.:D
I have already ordered the phosphoric acid, should arrive sometime next week.
If it acts like a dielectric, the resistance will grow. So it can only (i think) be measured on a potential, like in a setup for a capacitor. But it should be measurable to be different from ordinary SS..Quote from lamare on September 21st, 2013, 08:03 AM It could be a good idea to measure the resistance as a function of the voltage applied to the layer using metal contacts applied gently to the surface, for example using a known resistor in series with a adjustable power supply and then measure the voltage over the resistor and over the layer contacts.
Citric removes "less" than nitric in the sense that it removes the iron only and leaves behind the chromium and other metals. This is beneficial both from a waste disposal standpoint and from a corrosion resistance standpoint, as the citric leaves a deeper chromium-enriched layer than nitric.
And yes, the chrome oxide layer is formed not in the bath but in the air afterwards. This does not prevent citric from delivering equivalent or even superior corrosion resistance results.
Unbelivable HHO Production with 17.5 Amp
Electro-Polished Electrode Plates - increased Hydrogen Production and no Oxidation at positive Electrodes. Now you can run also high Amps without any Problems , all day long !
Pretty looking cell, but I wouldn't call the output at 17.5 amps unbelievable--looks quite typical to me. And because the plate surface is so smooth, doubling the amperage would probably show signs of thermal runaway. My Bob Volk cell is about the same size and can handle 40 amps with only a 5 degree heat-up from ambient. The difference: My plates have been roughened.
Brute force electrolysis is all about surface area--the more the better.
What I would be very curious of is if he can run high voltage, low amperage with distilled water...
what would happen if you use cling wrap or some thin dielectric plastic over the stainless?
Would ordinary knives/forks be electroplated?
A nice smooth finished surface in my opinion would help dislodge the gas bubbles more efficiently.
