What do you think Dog-one, you think ppl want to stop by force?
Suppose you went to bed one night and had a very interesting dream. In that dream you saw technology that was 50 to 100 years more advanced than anything we currently know about. What you saw was clear enough that you could build it. Maybe not fully understand it, but you could identify the pieces and assemble them as you saw it.
So you begin to gather supplies and put this device together, writing on the forum pretty much daily as construction unfolded. Then the strange emails, phone calls and visits start. This goes on for a couple of months, but you continue to make progress on your device. Now things get more serious. People you know start having weird accidents, you get pushed out of work for no apparent reason. And one day you walk into your garage to find things totally scrambled and your device missing. But you don't let that stop you; instead you get more parts and start building another one. That's about the time you find yourself in a hospital with tubes sticking out of your arms.
What I'm saying is yeah, this could happen to you, to me or anyone else doing this kind of research; I'm pretty certain it has happened to others. So what went wrong? Where was the first mistake made? I would say the biggest mistake was not getting the concept clearly documented and distributed immediately--within days of having the dream. Going at something like this as a lone wolf is a really bad idea. Even if you have the right attitude, the bad guys simply don't play fair. They won't fight you on even ground. They would rather add a few drops of poison to your water supply or some other sneaky rotten little trick. That tells you a lot about your enemy or better yet, your enemy's employer.
What we are doing here can be dangerous. Life in general is dangerous too, so one has to weigh the differences. Being a moderator of this forum, I have accepted the risk that a day might come when someone posts some very valuable information that will certainly put me in danger. I will have to do the right thing and be ready for any consequences. Beyond that, our power is in our numbers. They can't get us all and the truth will eventually get out. What I'd like to see is this: Instead of us living in fear of some sweeper team coming to our home and destroying our lives, I'd like to see our enemies in fear of us, knowing full well they cannot stop us, not all of us. For not stopping us, they will be punished. Let them sleep on that for a while and decide which team they'd rather be on.
So if I haven't made this point clear, let me reiterate. We are soldiers and we are at war. The battle has begun a long time ago. It's the same old good versus evil that has always been there. Each side thinks they are doing the right thing, but in the end there can only be one winner. For the meantime, the battle goes on.
Ok, thanks for your reply Dog one, i appreciate it.
You know that is exactly what happened to Hendershot with his energy device. He dreamed a dream, he made his device, it worked, then he was paralised by a electrical shock. So then he couldnt move nor speak, then he mysteriously died when he went to reveal how it all worked. Some say suicide, but that dont make sense.
Ok, i had no dream, but i have a dream, and this is to release water powered ICE to the world, especially to third world countries.
So Dog one, you have inspired me to release my plans for my device. Ill do that now. Ive done it already on Max's site. here goes,
Im am currently designing a power generator that can power your home (6.5 kva) and run on water. This is how it will work, basic version.
Fisher and Paykel washing machine motors are 3 phase 1400w motors that make make power at about 600 rpm when wired as star. Use as a alternator instead of a motor.
Modify the stator with thicker wire, 1.6mm, and use neodynium magnets instead of the stock ceramics. This will bring output to around 2kva instead of 1400.
We join 10 F&P smart drive motor together. This = 20 kva.
20kva = 200v x 100a @ 600 rpm. The power needed to run this is 20kw obviously, but when we consider only 90% efficiency of the motors we need to add 10%. So power needed to run the motors is 22kw. How much Horse power is that? 22kw divided by 745 (1HP) = 29.5hp, we will say 30 hp. 30HP !!!!! you say, we have no power left in the engine to run any kind of generator you say. All is not lost.
The engine, a Honda XR 400 dirt bike engine. 400cc makes 35hp on gasoline at 6000rpm. (they rev to 9000). 6000 rpm!!!!! You say, and only 5 hp left to do what, you say. Ok fair comment, this is what we do.
First, 20kva = 107.5 LPM on a 64 plate cell with 500mm x 300mm plates. This will allow 125a to pass through. we will be using only 100a so cooling and efficience shouldnt be a problem. Nor should 107.5 LPM running 400cc at 6000rpm. (not tested yet, all is theory and yes i know theory is theory and actual tests are something else, but im making this now and ill get back to you).
So we have the LPM but still only have 5hp left spare and we cant make any power with that. So what do we do?
Remember i said the engine revs to 6000 but the Fisher and paykel motors only need to spin to 600rpm (approx, testing them as i speak). So we gear them down from the engine at 10:1 ratio. this slows the Fishers to operating speed. It also cuts by 10 times, the amount of torque needed to spin those Fishers. 30hp divided by 10 = 3 hp. 3 hp to make 22kva of power. a 35 hp motor minus 3 hp = 32hp spare. That leaves alot of power left over, so we can adust down the rpm or use a smaller engine. (but ill stick with this formula until ive actually done it).
So now we have power to run a genset head from the Honda xr400 engine as well. Add one Honda 6.5 magnet motor generator and bingo, power your house on water. Now if we want to get really funky, we instead can add car alternators, a few of them, and then run an electric car with no batteries. Worlds first Hydro/electric car.
More detail is involved than ive let on. Ask and you shall be given. Matt
This is a vid of me testing a Fisher and Paykel smart drive. These are plentiful in Australia and NZ. If you cannot source one in the USA, go to ebay, they are for sale on there or find a whirlpool/LG washing machine, they have a similar smart drive motor.
https://www.youtube.com/watch?v=wSHLqIA3WFs&feature=youtu.be
