After long frustrating days of trial and error finnaly got it.~2000v at the cell and producing gas like 20v stait dc,but my trans was wound with salveged wire and dont had enough.
Here is my setup:
1.Vic coil transf :chokes:aprox. 500+wraps of 29awg i have 8 spaces because my laminated core is shorter than Stans.Secoundary 1000wraps 29awg.Primary 200wraps 24awg,over the sec.
2.The cell was the same dim as Stan's,but aluminium.
3.The pulsing was done with Tony Woodside vic(thanks very much buddy),but the swiching was done with an external transistor(bu208) at 30v.
It works also with 3 tubesets and also with ONE(how about that h2opower?)
-first the voltage is very low ~5-7v but when you aproach the resonant point the voltage will climb to 40v ,then 80v then max the meter.and stay that way.i did not used the feedback,but cell staid charged for a while...not shifting.
-resonance was achived at 8Khz.
I must say that you should listed Stan's words and experiece more than making up theories.The coils will not wind by itself.I worked for 2mounts on this setup 70% was with scraped parts....so keep experimenting.
ps.my pc scope wont read 2000v,so dont have a scopeshot...Cheers!
Here is my setup:
