A few milli-ohms can make all the difference in the world.
Arduino VIC resonator
But everything is now known enough to reproduce this now.
So by all means, if you do have it all figured out, feel free to share what you got, because I sure haven't, I guess if I'll ever get a chance to wrap my head around this I'd have to empty all my cups first as they're filled with quite a messy soup right now, to put it mildly.
Hi everyone. Ok here is my take on this sorry if I am stepping on toes. Stan was as some of you pointed out in earlier posts pioneering this in his garage. I do not believe he invented though. I can show proof later it has been around since probably before good Stan was born. What I think he reproduced was a high voltage plasma in the cell and not only was he creating HHO as a byproduct he was running the vehicle on mainly H2. He was creating the high voltages necessary by creating a vacuum which pumped the Ionized plasma through the rings of coils. He was pulsing the cell with the photo diodes or he was pulling from them. my guess is pulsing the cell with photo or light frequency to continue to disrupt the equilibrium of the cell as he was pulsing the tubes with a square pulsed wave which in turn split the H20 into HHO. He would pulse this HHO with a high frequency radio or light wave thus creating the plasma. Plasma would then be pumped through coils thus creating a charge in coils as it is continuously looped through the charging circuit. some of Hydrogen is sucked off going to the special spark plugs he created. these are basically like the ones I have seen here. remember he had to pioneer this stuff the best he could out of a garage. so he brings hydrogen to the plug because it is the most beneficial location within the cylinder right there next to where the high voltage plasma spark plug would ignite the hydrogen at as close to top dead center as possible thus creating the ability to run the vw engine. I think what most people do not consider is the VW was the engine of choice at that time for the home mechanic to play with. Simple and Could run it easier on vapor then american style. Now there are ways around this. lol. I would like to thank all of you for your parts in helping me put this together in my head. Ok enuff for tonite I am off to rest my noggin. I just knocked out this complete thread and am brain fried. lol. Ok parting thoughts there are easier ways then the way Stan did this. I know this now. I guarantee if he would have come along at our time there is no telling where we could have taken this. I am afraid though with todays current exopolitical views and greed he would still be at best lucky to live. Ok all I am done for now.
PnL,
Eyeindanorth
PnL,
Eyeindanorth
I'm wondering if anyone has come across any information on matching coils to wfc ( or injectors),
I realise stans coils have been replicated both for wfc and injector, it seems there is quite a bit of information available on stans coils but not much on how to build coils to match a given wfc or injector style.
Davy Oneness
Re: Arduino VIC resonator
« Reply #154, on September 4th, 2015, 07:10 AM »Last edited on September 4th, 2015, 09:03 AM
(I do believe that technology is actually classified, as I even seem to remember being on a tour of a navy ship way way back in boy scouts and being told that,and it wasn't even a nuclear vessel)
He was pulsing the cell with the photo diodes or he was pulling from them. my guess is pulsing the cell with photo or light frequency to continue to disrupt the equilibrium of the cell as he was pulsing the tubes with a square pulsed wave which in turn split the H20 into HHO."
Now get this, you mix in "non combustable gasses" ie "ambient air" to this mixture, and now you can adjust the burn rate to match diesel, gas, propain, natural gas........
So when I realized this, I started looking on youtube for anyone who may have experimented with this, and I found this guy:
https://youtu.be/7aTVu4SJ79w
So now get this, O3 is unstable so you have to create it close to where you are going to use it.
So if you think about the Meyers plugs now, the spark pug plasma can't ignite the gas! it is the O3 generator! So hopefully you all know that HHO can not be stored under presure because it will explode right? So the peak pressure of the compression stroke causes the gas to explode!
Some good study stuff if you haven't already:
http://www.sentex.ca/~mec1995/hho/Meyer/Stan_Meyer_Full_Data.pdf
Interesting video link davey oneness, I think from memory someone else had done a video showing same result ( ozone generator plasma and hho = no bang), I had forgotten about that finding.
I guess thats why they call it a 'cold' plasma. So in terms of the meyer injector it is possible no combustion due due to any plasma in the voltage zone. But exactly when the hho would explode due to compression would require experimenting. The hho would need to explode at the correct moment, which would depend on temperature and pressure of the cylinder, so I would guess you would still need a spark to detonate the hho at the correct timing, leaving it up to cylinder pressure/temperature alone I doubt would work. It needs to detonate at correct time, stan had gone to quite alot of trouble to work out how to change the flame speed of hho to match that of petrol/diesel. Which would mean its not necessary to adjust the timing ( thats my understanding of it). I suspect he delivered a pulse to the injector to initiate a spark at correct time, different to the pulses used to split h20 into hho.
Update for those real that are following. After some experimentation, it is clear to me that one of the plates needs to be insulated to prevent electron flow and make it as Stanly puts it, an " ideal capacitor" .I experimented with the set up without plate coatings, and the water just becomes electrified from current flow. Stan states for one cell the water has a resistance of 75oms(also states salt water can be used without problems even though even more conductive), so clearly the water is not the dielectric part of these capacitors. Instead the water is an extension of the negative plate while the positive electrode is insulated. In early stan prototypes, and xogen demo, the plates must be done with clear coat polyurethane, I think. The proof of all this is in Stan's car plug which is as he states,is a miniature compact version of his whole system, and the positive electrode has like 2mm ceramic insulation to prevent the current flow through in order to set up the electrostatic field for splitting. Why ceramic? because the poly is only good short term because of Ozone produced in the process will degrade the coating over time! So all those replications with "conditioned plates" was about discovering that the plates need an amp restricting coating, but don't do both pos and neg! Because I am pretty sure the Neg isn't insulated for best results. Wonder where people like ravi and lawton at these days, my guess is they are keeping their results private now that they found the key. It is getting cold here, so not sure if I can get my plates coated to continue till spring, so hopefully someone can pick up and share until then, that is if there are any experimenters left around here.
Something interesting I came across while doing other research:
"Water insulated delay lines, or capacitors, are used for the production of megavolt pulses on certain systems..."
https://books.google.com/books?id=XYSoBQAAQBAJ&pg=PA74&lpg=PA74&dq=%22water+for+insulating+high+voltage+pulse+systems%22&source=bl&ots=9Bn6muiJkc&sig=RUBhExa3Bhqt-UiFpuQZ5L5x7CU&hl=en&sa=X&ved=0ahUKEwj3y6HY9cLKAhWBZCYKHZTDCPMQ6AEILTAA#v=onepage&q=%22water%20for%20insulating%20high%20voltage%20pulse%20systems%22&f=true
the voltage zone where the water splitting occurs in the injector only has a gap of 0.01inch,
theres no ceramic in that section of the plug. Other parts of the plug play no role in water splitting, so the ceramic sections are to insulate the positive and negative voltages from each other ( flashover).
I have no idea if the stainless requires insulation to keep current down. Though once bubbles are produced they will increase the resistance unless they are quickly removed.
I think stans tubes in his estate were examined, I dont think they found any insulation, but they were in very good condition apparently. If you have metal/water interface on one side and resin/water interface on the other side, there will be different processes going on each side.
At the moment I'm thining no insulation is the way to go, but thats only from researching about water/metal interfaces. I'm still in process of building a pulse network based on valyonpzs' work.
Its interesting work your doing.
« Reply #161, on January 25th, 2016, 12:53 AM »Last edited on January 25th, 2016, 12:59 AM
distilled water is a perfect isolator for up to 100 µs:)
those megavolt pulses are of short duration and for those water is a perfect and cheap insulator.
calculating 100 µs to a frequency gives a pulse period of 200 µs and recalculating to frequency gives 5 kHz ...
Those 5 kHz perfectly fit into Stan Meyer frequency ballpark ;)
So water (at least distilled) is not just pure resistance! it´s a non-linear resistor and a capacitor at the same time.
this water "switch" from insulator to conductor might be the reason for high frequency oscillations in the LC network of VIC chokes and WFC.
btw. this discussion doesn´t fit to Arduino VIC resonator thread theme ...
Alberto
« Reply #162, on April 22nd, 2017, 06:28 AM »Last edited on April 22nd, 2017, 06:32 AM
Hardkrome
« Reply #163, on November 16th, 2017, 02:43 PM »Last edited on November 16th, 2017, 02:49 PM
my version on pcb
DimDimuch
« Reply #164, on January 31st, 2020, 07:15 PM »Last edited on February 2nd, 2020, 09:58 AM
Hardkrome
Hello dear Hardkrome! Please share schematic diagram of generator I will try to make it, with creative vision, so exited with you work. Thank you! Love And Light!
pdjboy
« Reply #165, on April 29th, 2020, 01:52 AM »Last edited on April 29th, 2020, 04:43 AM
Hi. Gate LED does not work. It is necessary to add some lines.
Code: [Select]
Timer1.pwm(GATEOUT, duty, 1000000/gatef); //turns on Gating signal to pin 10
digitalWrite(GATELED, HIGH); //Turn ON GATE out LED
volt = analogRead(PICKUP); //read the voltage on the VIC
//*Needed to uncomment this line for the pick up coil voltage to be read during gating - firepinto 10/25/14
if (volt > 818) //If pickup coil voltage is over 4 volts at pin, light LED. *Added by firepinto 10/26/14
digitalWrite(PEAKLED, HIGH); //Turn ON pick-up coil peak voltage LED
else
digitalWrite(PEAKLED, LOW); //Turn OFF pick-up coil peak voltage LED
digitalWrite(GATELED, LOW); //Turn OFF GATE out LED
Hardkrome
