https://www.youtube.com/watch?v=5M6uI9uZARAhi, i was thinking about what h20 said in his other post about the making of the magnetic gas. load Stone is magnetite, and oddly its cover the crust of earth, very interesting. the way to make a magnetic gas can be as simple as take gas helium, then do nothing to it. add tiny magnets and you have a dipole source for emf movement, all you do is hit it with high pulse of current, but this must be done with 12 volts. because you may use a capacitor to get the volts even higher. the source should be small as possible. for experimental purpose a gas such as nitrogen may be added. then spark gap dipoles of magnetite carbon and iron oxide. this again will add a dipole source, and a pulse from a coil will give a movement. the energy alone in this movement should be observed. then we add the laser to see if electrons are brought to higher energy by the dipping into of the virtual vacuum. 0 point it is. have you seen the bladless fan? it makes a wind tunnel not based on Tesla s circuit, but in his experiments he did with a smoke filled room, and a cold electric field effect. the cooling of space through vacuum particles unidentified. remember there was a cold wind also. so it was really rushing too. imagine a cooling unit based on this idea alone. the energy circuit is identical to the ionic breeze machine. it can be duplicated a third time, but with a larger scale. Dr townsend brown, also shewed the Tesla circuit with his experiment with anti gravity and sound. if you recall he had a large washboard and it made clean sound. similar is the Rodin coil, but it is the circuit alone that is golden..
what is important is we identified the steady ray or near and far infra red spectrum. and conclude this as a source of induction on dipoles and atoms.
