Hmmm... Well, after taking stock of available resources (and abilities), I'm now started on my own Tesla coil -BUT- It'll be "different". Remember, this is Cheyenne, Wyoming - parts and materials are not as readily available as everywhere else (yep, it's primative here). Sadly I can't go out and buy a roll of magnet wire, or a 6kv neon sign transformer, etc. OTOH, I do have accumulated resources of my own to draw from.
One thing that was hindering me is the thinking that certain things had to be that certain way and nothing else (even the heavy math), but I have recently realized that EVERYTHING is highly variable. For example: It does NOT take 6kv to get high v from a Tesla. When something like a Slayer Exciter can get HV from 1.5 vdc, I'm convinced just about anything (like a 1.2kv fence charger I have) can be used to excite the primary.
So, for the secondary, I have a stout 3 1/8" cardboard tube, 24" long. For wire, I have 15 lengths of approx. 22 ga. stranded (7) computer cable wire, 15 ' each: 240' when spliced. It has some pretty tough double-insulation on it. The outside burns but the inside is still impossible to strip with thumbnails.
For a primary (since I used all my Romex on the last job before I broke the screw in my wrist plate), I have no choice but to use steel baling wire (!)(?). I've been noticing that some primaries consist of no more than about eight turns of heavy wire, well spaced and thus, well insulated (sort of). I can certainly accomplish this with steel wire (especially since the fence charger can't jump very far at all).
I had asked what a metal-core primary would do - well, we'll sort of find out, huh?
For the upper load, a pair of cheap stainless steel mixing bowls, inverted one on another, held together by spring clips ought to do it.
The secondary wire I have ought to give me a coil about 19" tall. I want to make it so primary coils can be easily interchanged.
Sound like a plan? Well, that's my story and I'm stickin' with it! :D
Gary S.
