Dust-Based High Voltage Generator
I discovered this high voltage generator quite by accident. I was vacuuming powder coating dust in the exhaust plenum of a powder coating booth. I was standing on a fiberglass ladder, when all the sudden, about an 18" lightning bolt jumped out and struck me in my right buttock!
This was an air powered, 55 gallon industrial vacuum (no moving parts) with a long, heavy, plastic industrial hose (kind of like a pool hose). Now I knew what the terminal with the wing nut was for (I inherited a maintenance department in disrepair). So, I sucked a wire down the inside of the hose and out the business end, wrapped around so as to contace my hand. The other end went to the terminal, which had another jumper going to ground. Even then, when I got into some heavy dust, I could still feel the high voltage pulsing on my hand.
Although that involved static-charged powder coating powder (same as copier toner), the same thing happens at home with sawdust and other kinds of dust. If isolated from ground, anyone holding the hose becomes a "collector"; it can pack a kick! Just about any kind of dust will work, but plastic-based dust like powder coating powder has the problem of "impinging" on the leading edge of any fan it passes through, eventually building up enough to flake off and throw it out of balance.
Even though that hose was about 50' long, it does the same on shorter (plastic) hoses. I think the effect would be greater with a longer hose, but it needs to be kept off the ground, or the static charge will bleed off to ground. When vacuuming saw dust, you can feel the hair on your arm rise and see some sawdust accumulation on the outside of the hose, so you know it's kicking out some volts.
Now, what would happen if you made something like this, but BIG? A closed loop of 12" PVC pipe, a powerful fan, a 55 gallon drum for a collector on top of a 16' ladder maybe... hmmmm..... *SNAP*
Gary S.
Gary S.
maybe we can learn Tesla's secret.
