Unification Coil
RE: Unification Coil
« Reply #1, on December 11th, 2012, 10:33 PM »Last edited on December 11th, 2012, 10:34 PM by Matt Watts
First, show me closed-loop operation with no batteries. I'll accept capacitors but no batteries. Pulsing coils and trying to measure voltage and amperage with a digital meter is usually pretty dire. They need to charge caps, so we can get a better feeling of electrical volume, flow rate.
Two, how on earth is that thing wound? Looks like a glob of wire. Wonder if they glued it that way or if there is some sort of structure underneath.
Lastly, if that is stray magnetic or electromagnetic radiation being given off, I would be curious to know what health effects relate to this thing running. Maybe it needs to be put in a Faraday cage and run. Would be interesting to know if their rough math still holds.
Other than my usual skepticism, it looks pretty cool.
You can buy a preassembled coil for $600 or a kit for $250.
If it is overunity it should be possible to get it self sustaining in a closed loop, I agree.
No batteries, nothing attached to a wall socket, maybe just to get the thing started but after that it should be running all by itself.
What if it's an elaborate joule thief stealing electromagnetic energy from the surrounding electric installations?
If so it wouldn't work if put to the test out in the middle of nowhere.
Worth following though, thanks for sharing
Hmmm... Here we go again. A few comments I have:Quote from KevinW-dirtwill on December 11th, 2012, 09:20 PM
I too, was thinking about the health aspects of this devise as well. :huh::DQuote from Dog-One on December 11th, 2012, 10:33 PM Hmmm... Here we go again. A few comments I have:Quote from KevinW-dirtwill on December 11th, 2012, 09:20 PM
https://www.youtube.com/user/jamiebuturff/videos?view=0
On the other hand using the wrong frequencies could be bad for your health...
« Reply #5, on December 12th, 2012, 07:46 AM »Last edited on December 12th, 2012, 09:06 AM by ~Russ/Rwg42985
I have talked to Danial about some negative effects i have experienced.
by the way i spent about a year or more studding this and the math behind it.
now... i do believe that some "magmatic radiation" is a good thing. it all has to do with water. and sense we are maid from water... we are affected by the coils output. could be positive or negative... ( i have talked to people that inbeded water with codes to heal particular things. i have herd to Manny different people tell me the same thing that never have talked to each other that i am convened water will do such things. )
he states a good thing by being around the coil... ( there are Manny meany story's of healing with coils of such)
I will tell you that i have been negatively impacted by the one coil i have played with ( maid me sick and i stopped using it, felt better, started using it again and got sick. no joke. it messed me up in ways i have never felt...)
now, i was using high power and magnets... not resonance and other stuff. and that's not what Danial is doing, he is using resonance and all the good stuff like that that we want...
I have a hard time with the way he measures stuff... but at the end of the day the only way to find out is to build and test your self. and that's what i will be doing. ( its on the list...)
i have all ways believed in the math behind the coil and that this coil was something that may "tap the zero point" as there is so much in this coil that we see in nature.
now my hats off to Danial, he found a way to get the wire to stay in place with some simple slotted plastic pieces. this was the overcome for anyone to make these coils... i still haven't finished the gluing wire on torses... just so much work... but he has got it! its genius.
any way you can see all my work here :
http://rwgresearch.com/open-projects/vortex-base-math-research/coils-testing/
http://rwgresearch.com/open-projects/vortex-base-math-research/the-math/
and i will pick it back up asap as it all ways has intrigued me to keep testing theses coils. using what Danial had given us... should be amazing, i cant wait.
attached is the doc i made to understand the proper way to energise the coil...
i believe that once we get to 144x144 coil we will start to see the real results of the math/coil "sweet 16" its all there... we just got to keep working on it. GO Danial GO!!!!
Vulcain67
« Reply #6, on December 12th, 2012, 10:30 AM »Last edited on December 12th, 2012, 10:36 AM by Vulcain67
Have anyone seen this video ? https://www.youtube.com/watch?v=lEV5AFFcZ-s
At the beginning they talk about toroid and infinite energy...
any how "fallow the money" lol this is why we are here now... its a sad place we live in... Greed and egos are so much fun... ~Russ
trust the truth
geenee
« Reply #9, on December 12th, 2012, 10:10 PM »Last edited on December 12th, 2012, 10:53 PM by Matt Watts
So if you can create a monopole electromagnet as shown here:
https://www.youtube.com/watch?v=KA4uldn2CYg#!
Then one would think you could build a motor that essentially accelerates endlessly.
I've seen all sorts of stuff claiming they have a monopole permanent magnet, which all appear to be hoaxes, but this thing seems to be the real deal.
And you too can make one:
https://www.youtube.com/watch?v=FDqq5W8bGRs#!
I have a whole spool of Essex wire calling out for a new home...
You guys here anything new on this?
I saw a guy by the name of Roland Gregg on Smart Scarecrow the other night saying they have a UL certified lab in Las Vegas, Nevada that is working with them to make a low-energy lighting system. Roland also did a short demonstration, but I totally disagree with the readings he was showing. Have a look:
https://www.youtube.com/watch?v=RxpdJwI14Gs
One just can't use those handheld instruments with inductive audio frequencies and expect to get any meaningful numbers. Probably why the thing has never been close-looped. Guess I'll have to build one, power it with my PA amp and signal generator, check load at the wall plug, then rectify/filter the output with a bridge and large cap. I'd be real surprised if true usable output power is anywhere close to the input power. Truthfully, I'm not interested in another high-voltage spiking battery charger. I'd like to see if this coil is actually capturing radiant energy and adding it to the output.
Hey, thank you for your sort-of-book :) I am deep in making the coils I am trying to replicate the unification/Rodin coil setup, however I lack knowledge, could you perhaps explain in greater detail the whole connection of the coils? Because as I see it now, there is an amp that is connected to a wave maker, and from it wires connect to the coils. This is where I struggle, which wire is connected to which coil and what winding? Thank you so very very much. Peace!
« Reply #13, on August 3rd, 2013, 05:14 PM »Last edited on August 3rd, 2013, 05:16 PM by Matt Watts
Have a look here:
http://open-source-energy.org/?tid=1141&pid=16678#pid16678
You are in effect taking all that wire you strung into two wires that go back-n-forth. So you have four ends:
Hook your amp to Channel A Start and Channel B Finish, then your load to the last two wires left. In Erica's video, she shows you the final schematic for just a moment.
- Channel A Start
- Channel A Finish
- Channel B Start
- Channel B Finish
a twenty foot magnetic field. that is very large for a coil to produce such far magnetic inductions, without the need for a tesla coil and spark gap.
« Reply #16, on August 8th, 2013, 08:31 PM »Last edited on August 8th, 2013, 08:32 PM by freethisone
Yes it is and Daniel states this large field has a healing effect too--that's typically a little rare for an energy device to have such a side effect.Quote from freethisone on August 6th, 2013, 02:58 AM a twenty foot magnetic field. that is very large for a coil to produce such far magnetic inductions, without the need for a tesla coil and spark gap.
but there is a lot of research in that field with better results, because they were tested.a field magnet is important. you can rotate an axis in that field. also you can rotate the field itself. many uses.:cool:
the universe is on a inward spiral. that is why the toroidal coil works well.
but a thick Tesla bifiilar will do a good job also.
