Here is the DFX Cad files of the engine, with dimensions etc. I put it inside a zip file - Happy Building
Boots-2b1
Boots-2b1
Thanks for the information and pics Boots! The pictures show a lot more complexity than I originally thought, I can see where one could spend a lot of time getting the tolerances just right. I originally thought the outer plates were stationary, but looks like they spin with the internal components. If the outer collar is stationary, how do those outer plates contact the collar?
All of the components are Bolted together and the mass spins as one peace keyed to the drive shaft with in the outer lids. The pistons turn on their own shaft with in the block. It is fairly easy to balance and true. You mount the block and plates together with the keyed drive shaft in a lath with the drive shaft in the chuck. Then you true the outer plate on both sides - that's it. The most difficult part is cutting the pistons, I sent the job out and had it wire EMT cut because of the pistons tight radius. The rest is a peace of cake for a good machinist just a bunch of circles. I built the entire engine in my garage.Quote from Badger on December 19th, 2012, 07:24 AM Thanks for the information and pics Boots! The pictures show a lot more complexity than I originally thought, I can see where one could spend a lot of time getting the tolerances just right. I originally thought the outer plates were stationary, but looks like they spin with the internal components. If the outer collar is stationary, how do those outer plates contact the collar?
Merry Christmas, Boots-2b1
Ok, I got it now. I had to look at the patent again, the outer lid with the main bearing isn't in the pictures. So the collar and outer lid is stationary, and that main bearing keeps the internal mass away from the collar just barely, right?Quote from Boots-2b1 on December 19th, 2012, 09:54 PM All of the components are Bolted together and the mass spins as one peace keyed to the drive shaft with in the outer lids. The pistons turn on their own shaft with in the block. It is fairly easy to balance and true. You mount the block and plates together with the keyed drive shaft in a lath with the drive shaft in the chuck. Then you true the outer plate on both sides - that's it. The most difficult part is cutting the pistons, I sent the job out and had it wire EMT cut because of the pistons tight radius. The rest is a peace of cake for a good machinist just a bunch of circles. I built the entire engine in my garage.
I'm still interested in trying this out, I'm working on a variable resistance load bank and found a custom EFI kit that would work great with this. I still would need to scale it down though, I'm not set up for V6 power.... let me know if you have a contact that could fab up a smaller one.
