I've been trying to get Sketchup to work on my Ubuntu machine for awhile. I was using Virtualbox but now that don't want to run. So I searched for another fix and found one that works!
The following is from the link below:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=9&ved=0CHgQFjAI&url=http%3A%2F%2Fgroups.google.com%2Fgroup%2Fopenwonderland%2Fbrowse_thread%2Fthread%2F2c31b90e5cc8eed9&ei=6xy5UIyIB6a3ywGx1oDACA&usg=AFQjCNGDRVPiRVukvB7U93wlQwys3KJbdg&cad=rjaQuote There was some things I had trouble with because I don't know much about linux. One thing is saving the sketchup install file in the system32 folder of wine(windows). You have to unhide folders in your Ubuntu home folder by pressing Control-H. Then you can browse to the .wine folder and find the windows file structure under that. The other was saving the winetricks page, if you save it in the home folder the commandCode: [Select] will work. All of the install is done through the terminal window of Ubuntu.
Well just after I posted I couldn't get sketchup to run a second time! Thankfully I found another solution to the problem here:
http://ubuntuforums.org/showthread.php?t=1353335
So far its working again. :cool:
First, I'm using Ubuntu 12.04 --with older versions, YMMV.
I went here first.
http://www.dedoimedo.com/computers/google-sketchup.html
Nice straight forward instructions, which usually are doomed to fail.
So, first thing I did was add the wine ppa to get the very newest version.
sudo add-apt-repository ppa:ubuntu-wine/ppa
sudo apt-get update
sudo apt-get install wine
sudo apt-get install winetricks
That will install the latest and greatest version of wine and winetricks
...almost. Sorry, another step here.
The winetricks package is installed, BUT the script (it's not a binary
file) in /usr/bin isn't the latest and greatest and failed to install
all the Windows files, that article mentions. I know, MicroSoft is a
moving target as well.
So, one more hoop to jump through using your browser go here:
http://winetricks.googlecode.com/svn/trunk/src/winetricks
You'll get a page that is a bash shell script, save the page as
"winetricks" ...then, in a terminal window, type:
sudo cp winetricks /usr/bin
...to write over the old file you have there.
WHEW!! Now, as your user, type: winetricks corefonts vcrun6 vcrun2005
...and it'll run. Agree to each license acceptance screen that pops up.
One was German so hit "ya" for yes!
Next, head here for Sketchup
http://www.sketchup.com/intl/en/download/gsu.html
Agree and download the WinXP version
Lastly, type: wine GoogleSketchUpWEN.exe
Take the defaults and pick a template. If this doesn't run ten times
faster than your previous attempts, Bob's your uncle.
You will see an new icon on your desktop that is a shortcut to sketchup,
which makes it easy to launch.
Enjoy! I am blown away with how fast it runs after a zillion other
failed and half-baked attempts. Plus, it correctly opens a browser to
access Google Warehouse from the menu bar!! But, I have to save the file
as it won't import into Sketchup directly. So, I'm looking for a plugin
for Chrome. Ric
p/s MAKE SURE YOUR VIDEO DRIVER IS INSTALLED! But, if you're running the
OWL client, most likely you are covered.
My father, Victor Moore (Vic) used to say:
"There are two Great Sins in the world...
..the Sin of Ignorance, and the Sin of Stupidity.
Only the former may be overcome." R.I.P. Dad.
http://linuxcounter.net/user/44256.html
sudo cp winetricks /usr/binNate
