These Tungsten Spark Plugs were made to support new ideas for burning fuel better. Great for racing, generators, what ever reason. Also, laws are moving up on cleaner burning engines. There are benefits from these plugs that no other plug is able to deliver having a solid core and no resistor like these do.
I'm sorry to say that the amount of time and cost for us to build these plugs anymore needs to be ended. Get them while they last.
For Sale first time seen ( that I know of ) experimental 14 mm. Double Pure Tungsten spark plug that has a standard ground strap with a pure Tungsten cap welded on. These are gaped at .040 This plug may require a extra crush washer because the ground strap section is about .30 longer from welding. The center electrode is a solid pure Tungsten stepped shaft. The steps interlock the center electrode from moving and is also glued with high heat glue.
These plugs are made to withstand much larger amounts of current form ignition systems with way more power. Where other plugs burn up, these last much longer. They are experimental spark plugs and we have heard good reports so far on our plugs.
We have other types of plugs if this type does not meet what your looking for.
All our plugs are Solid Core, No Resistor, For Many Types Of Applications
The shipping cost stays at $6.00 no matter 1 or 8
Because these plugs are advertised other places they can be sold out anytime.
