Okay, here goes...
Tom Bearden's Massless Displacement CurrentThe basic principal has two options. One, if you charge a capacitor through a "special material" you can do so without paying for the current that would normally be necessary. Option two, you can step charge the capacitor in tiny increments and again not pay us much for charging the capacitor as you can get out of the capacitor once it is charged. Cool stuff huh? I thought so too, but I never made either option work in practice.
Edward LeedskalninFrom what I gather so far, his theory boils down to this: Electrons are rocking horse manure made up by guys with long hair. Electricity is really a combination of North and South magnets moving through a wire. These unipolar magnets are much smaller than photons and can penetrate any material. They really like metal but can traverse glass, plastic, air; basically anything. On a battery, the North magnets leave out of the positive side and South magnets leave from the negative side. Both North and South magnets must be moving in order for you to perceive anything resembling an electric current--they do not travel alone as just North or South, only in pairs. Their movement is in a corkscrew pattern rotating to the right as they move forward. Current (amperage) is just a measure of how many magnets are moving. Voltage is how much tension is on the magnet strands as they move. This movement has been compared to a double helix like strands of DNA.
According to Ed, Natural A/C is abundantly everywhere and looks something like this:
https://www.youtube.com/watch?v=HNHrkpz0uTsObservationsIt seems probable there is something special about a transformer being wound in a bifilar configuration which looks a lot like strands of DNA (also something pretty special). Very possibly because you have essentially a highway where one lane is moving in one direction and the adjacent lane is moving in the opposite direction. Remember these magnets are twisting as they move forward with some tendency to want to jump lanes if that makes their motion easier. Think about the last time you went bowling and threw a gutter ball.
Energy (tiny unipolar magnets) are abundantly everywhere but without some help we can't directly use them.
Step charging seems to be a common phenomenon in success stories we have seen.
Water readily breaks down with high D/C current but takes more energy to do so than you can get back by combusting the resultant gases. High voltage and water seem to only mix when the water has a neutral pH, so current seems to me to still be key. And if we are talking magnets like Ed would, lots of magnets means lots of bubbles.
The little magnets like to move in a corkscrew fashion, forward and to the right, so mechanically we may be able to leverage their force since we can anticipate their movement.
These magnets also prefer to travel through metal but probably can be made to travel through insulators if we are able to bind them up enough.
ThoughtsSuppose we are able to wind a bifilar coil in such a way where it is acting as Tesla might define, an electrostatic oscillator, just bouncing natural, inherent A/C around inside itself. Not doing any work, just sitting there like one of Ed's Perpetual Motion Holders (PMH). Suppose this coil is attached to our water fuel cell or simply our output device that just so happens to have water in it. Now imagine there is a way to slip a little extra "natural" energy (magnets) in there without us doing any real work. My guess is that some natural equilibrium will happen to even everything back out and suppose the only way out is via our output device.
GoalSo if built properly, our little coil (maybe by way of diodes, another winding, shielding, grounding, who knows at this point) tricks more natural A/C into hopping into the bifilar windings when there really isn't room for them; thus, they get pushed back out and end up in the water. So think, little tricks (step charge, oscillations faster that the coil can keep up with, getting the magnets to go the wrong way). Maybe we can even control how many additional little magnets we let in before we decide to let a whole bunch of them back out into the water--think gating. What we want turns out to be very similar to what Stan built, though we may have gotten to the same place from an entirely different direction. It's this alternate goal that is every bit as important as the main goal--we need to be open minded and not let the trees block out the view of the forest. One of us CAN figure this out, I just know it. Hopefully, whoever it is can explain it so that we all "get it".
Gut FeelingI played with this darn thing for quite a while and my gut tells me the answer is in the coil and how we pulse it, not the cell. I think most any cell would work and I'm willing to bet that if you figure out the coil, you could hook it to a massive cell and blow yourself up in a matter of minutes. I also think if you harness the natural energy, your cell won't get hot like it would attached to a large D/C power source. Probably because in effect you are dumping massive current into the water in very short bursts; the water doesn't have time to heat up, it just flies apart into gas rapidly. Also, if you think magnets both flowing out each wire, one side North and the other side South, you don't actually have current (amperage) until the two streams of magnets collide and if that collision is in the water and not in the wires, you can use small gauge wires without burning them up yet see the cell generate large quantities of gas as though it had been hit with a thousand amp burst. You only pay for the current that actually crosses through itself and makes it all the way back to the source which a properly made coil should never allow.
Next StepsBuild, build, build. Think about some of these concepts and test them in practice. If things don't work, figure out what it is you are not doing. If you discover something new, tell all as soon as you can find the words. Also focus. Stay in the game and don't wander off. Make a list of "I don't know how to ____" and figure it out. Ask for help. And above all, enjoy your journey. As I like to say, "If you aren't having fun, you aren't doing it right."
