V.I.C. Resonant Choke Insulation Questions
Sirgoose
« on August 21st, 2012, 06:27 PM »
Does anybody know how its possible for the wire used for the resonant chokes to withstand 10KV-20KV without insulation breakdown? Stanley Meyers combined his step-up transformer, pick up coil, and resonant chokes on one core without problem. Did he use a very good insulation or type of high voltage electrical tape? If anybody knows i would love to hear it.
RE: V.I.C. Resonant Choke Insulation Questions
« Reply #1, on August 21st, 2012, 11:10 PM »
Quote from Sirgoose on August 21st, 2012, 06:27 PM
Meyer used wire with very thick insulation. that meant a small wire diameter but a large outer diameter. this wire has to be fabricated on demand.
you can try to use transformer oil or
synthetic resin applied in a vacuum condition.
geert8550
« Reply #2, on August 21st, 2012, 11:35 PM »Last edited on August 21st, 2012, 11:40 PM by geert8550
Quote from bussi04 on August 21st, 2012, 11:10 PM
Has anyone here heard of high voltage wire???? :huh: This is used by the ignition transformer for oil fuel burners, and transformers in microwaves.
Just available from the wholesalers for electricians.
Webmug
« Reply #3, on August 22nd, 2012, 02:36 AM »
all dielectric coatings having an effective 3KV per mil dielectric value and formulated
specifically to endure automotive temperature range from _ 40 0 to 1550 C.
He makes use of "The Electron Inhibiting Effect" or EbP almost 'no' current will flow and you can not have a short!  That's what the VIC was designed for, to prevent current flow!!!
Regards!
« Reply #4, on August 22nd, 2012, 02:06 PM »
Quote from Webmug on August 22nd, 2012, 02:36 AM
Regards!
Webmug,
that's no protection against high voltage. imagine static HV. it will destroy the insulation but no current will flow until insulation breaks.
Stan spoke of double insulation he used.
