i would like to describe an experiment for any one to try.
you would need 2 or more lasers. one infra red, one UV blue, and one Green if possible.
the idea of certain materials can exist in a state of vacuum were energy consumes the material to full absorption. the dipole, that single pole has a spark and a discharge. we may charge them to a capacity of energy, according to its elemental properties. in the idea of light able to produce gravitational influences on surrounding matter. in this case as a carrier of vacuum energy.
the way to do these experiments. contained if possible to a reflective confinement you place a gem stone made of magnesium iron oxide and silica. this green stone is called a peridot. the experiment should be created as to introduce / project these three laser energy's on the stone. to contain any photons in response to the light sources, or lasers.
;) example : as a crystal, under vibrations of direct light influences of the combined laser sources. tourmaline, quartz or ruby.
diamond is pure carbon, carbon is said to absorb energy or magnetic radiations. These crystals would charge until saturation. conducting, or ferrous materials within the stone will play a major roll in the experimental data obtained.
This theory is based on an object of certain materials, or property, that may become higher energies in the presents of 2 or more light sources of a specific order. next you could try a continuous spark upon said stone and continue to reflect the photons in a chamber. The assumption is that an atmosphere would be produced around the stones, and that would contain said magnetic particles. energize these stones, as the lasers are also a fuel. there must be some ability of the gem to conduct. oxygen as an example. iron oxide. with that the energy surrounding the stone to become the higher potential, because the energy would thereby be in the outer shell, due to the conducting properties that expand atoms and stretch them into a gaseous conducting fluid.
The silicate minerals make up the largest and most important class of rock-forming minerals, constituting approximately 90 percent of the crust of the Earth. They are classified based on the structure of their silicate group. Silicate minerals all contain silicon and oxygen.
add source audio book.
Click here:Dsimilar conducting material From Wikipedia, the free encyclopedia
For other uses, see Asbestos (disambiguation).
Fibrous asbestos on muscovite
Asbestos
Blue asbestos showing the fibrous nature of the mineral
Asbestos"unquenchable" or "inextinguishable")is a set of six naturally occurring silicate minerals exploited commercially for their desirable physical properties.
note the last picture, and the material it is said to be made up of.
Deep Impact space mission
The head-on collision of comet 9P/Tempel and the Deep Impact impactor
On 4 July 2005 at 05:52 UTC (01:52 EDT), Tempel 1 was deliberately struck by one component of the NASA Deep Impact probe, one day before perihelion. The impact was photographed by the other component of the probe, which recorded a bright spray from the impact site. The impact was also observed by earthbound and space telescopes, which recorded a brightening of several magnitudes.
The crater that formed was not visible to Deep Impact due to the cloud of dust raised by the impact, but was estimated to be between 100 and 250 meters in diameter and 30 meters deep. The probe's spectrometer instrument detected dust particles finer than human hair, and discovered the presence of silicates, carbonates, smectite, metal sulfides (like fool's gold), amorphous carbon and polycyclic aromatic hydrocarbons.
Light energy, and the magnetic field is absorbed, and therebye held as a charge. until said discharge. The magnetic field adds more of a pressure. a mesure of gravity, due to its max flux, and the nature of material with ability to conduct energy.
more info below
magnetite crystal along three axes was measured in fields up to 5000 gauss. The curves obtained are all similar in form, first convex towards the H axis, then concave, tending toward a maximum near 5000 gauss. With a longitudinal field of 5000 gauss, the digonal axis expands 30(10)-4 per cent, the trigonal axis 12(10)-4 per cent, and the tetragonal axis contracts about 4(10)-4 per cent. With an equal transverse field the percentage changes are a contraction of 44(10)-4, a contraction of 28(10)-4 and an expansion of 4(10)-4, respectively. Tests indicated that the effect perpendicular to a plane is independent of the direction of the field in that plane. No departure from cubic symmetry was established. To explain these results a model of the magnetic element in magnetite is suggested, similar to Ewing's recent model. The experiments favor the view that the rotating magnetic element is a group of non-parallel electron orbits inside the atom. Permeability of a magnetite crystal was roughly determined to vary from 1.2 to 1.38 as the field strength increased to 5000 gauss.
somthing about light and cold space, somthing about a static medium or vacume.
the ability of objects that conduct show clear evidence that light can be used as a carrier of energy.. take forinstance silicates, is it really that easy? atoms that contain oxagen are carriers. a gem stone in an ice cold bath, introduce laser energy magnetic field pressure, and a static source. the addition of salty water is were the charge will be mesured.
