Electrolysis101PDF Download
Hydrocars
« on August 5th, 2012, 01:46 AM »Last edited on August 5th, 2012, 02:34 AM by Hydrocars
Russ, I wanted you to have this because I know when you look at it you will make a video of it once you understand it. It is important for this technology as production is not everything. There could be certain steps to producing lye and reusing it in the system without adding anything, and the output results could be more than just hydrogen and oxygen. We are in the early stages at understanding this.
Also, in one of your videos you tested the burn rate of hydroxy gas, you should know when using Lye your test would have been different because Hydroxy produced without lye doesn't compare to hydroxy produced with it, the gas is not the same it is very different.
Hydrocars
RE: Electrolysis101PDF Download
« Reply #2, on August 9th, 2012, 12:38 PM »Last edited on August 9th, 2012, 01:37 PM by Hydrocars
I'm surprised at the lack of comments! & Thanks VWType181
And the Famous Carbon Element Reveals itself.
(OH I KNOW THAT)
Imagine a cup full of gas taking you 1000 miles! This is what the technology had to offer and it was missed! It was hidden away, it was buried!!! The videos arent fake they just dont show everything. Now look in the right places and face the facts, Start piecing it together and get it finished!  Anyone with a mechanical mind can take this information and put it to work. Its similar to a geet but the geet doesn't quite cut it. A new synthetic fuel is born!
The same post here can be seen http://www.ionizationx.com/index.php/topic,2467.msg23137.html#new and I will also include a link to this post on this site on ionization as well.
Russ, I admire your videos.
Download below
« Reply #3, on August 16th, 2012, 04:05 AM »
Quote from Hydrocars on August 9th, 2012, 12:38 PM
(OH I KNOW THAT)
Download below
hello Hydrocars, thanks for the info. i just got around to seeing this.
i was indeed using the sodium hydroxide in the burn rate testing.  i would be interesting in trying what you have here in the drawing... just use the incoming HHO to agitate the gas up and burn vapor and hho... that sounds like a good test... will give it a try. some time... lol thanks for the support my friend!
Blessings! ~Russ
