Hi, I recently read the "Stanley Meyer Explainded" thread over at overunity.com and came across the common problem that no one seems to be able to get a high voltage to develop across the WFC.
The suggested problem is that the WFC has too much of resistace (ohms), all of you experimenters are using a single WFC right? The VIC transformer dont put out enough amperage to drive the voltage very high with such a high resistive load (single WFC). Is ohms law applying? U = R * I? He is comparing it to match a speaker to an audio amp, a too low ohm speaker (ex 1 ohm) is going to burn up an amp rated for ex an 8 ohm speaker.
The solution would then according to the thread be to connect more WFC cells in series, the resistance would then increase and a higher voltage would be allowed to build up.
I dont know how Meyer himself wired the VIC´s to the actual cells but here is a picture that show 10 of the 11 cells hooked up in series:
Here is the link to the thread:
http://www.overunity.com/7030/stanley-meyer-explained/240/#.UBrmG1JHHi4
Hope this can be to some help!:)
/viktor94
/viktor94
