Let's look Pakistan Inventor.(Agha Waqar Ahmad)
phil
RE: Let's look Pakistan Inventor.(Agha Waqar Ahmad)
« Reply #2, on August 2nd, 2012, 07:25 AM »Last edited on August 2nd, 2012, 07:27 AM by phil
I have a friend whos  is from that neck of the woods, im already asking round, and will subtitle the videos if i can get a good enough translation. Hopefully i can find someone a bit technical to help out so dont lose too much detail in the translation.
There were more than 3 vids posted here yesterday, where the others gone? There were two about 7 mins long showing close-ups of the bike.
geenee
« Reply #3, on August 2nd, 2012, 10:51 AM »Last edited on August 2nd, 2012, 11:11 AM by geenee
Quote from phil on August 2nd, 2012, 07:25 AM
about 3 motor bike videos??
i'm not sure(that is hho bike).motorbike videos isn't  Agha Waqar Ahmad.but if you need a link.-->>
https://www.youtube.com/watch?v=5xbrueBtMmc
https://www.youtube.com/watch?v=WxhBUGEpFp4
https://www.youtube.com/watch?v=j8bFIg0lSvc
https://www.youtube.com/watch?v=s5Cu022LYFE
thanks
geenee
geenee
« Reply #4, on September 17th, 2012, 12:56 AM »Last edited on September 18th, 2012, 06:40 PM by geenee
Is there anyone out their that can translate to english???
this video
https://www.youtube.com/watch?v=ENshccXLens
i tried to listen.he talk about water capacitor and use minimum current??about resonant???Meyer tech???
thanks
geenee
At last this's tech block from Gov and making news "he's fraud".you know why!!!!--->>>https://www.youtube.com/watch?v=OibqdwHyZxk
https://www.youtube.com/watch?v=L5NAUlkNhOk
PDF attached = explain his work
adys15
« Reply #6, on July 30th, 2013, 02:19 PM »
how do you know the guy in the car did  swich from gasoline to hho?how can a couple of plates hooked to a batery is able to produce resonance efects?or even run a car,lack of proof=fraud
adys15
« Reply #8, on July 31st, 2013, 01:14 AM »
i watched that crap some time ago.he uses a poor batery strait dc and claiming resonance bs....Have you seen the production from his plates,@200cc\min not that canot run even the smallest scooter.One more thing...why he is using for demonstration only CNG equiped cars?you know why?because cng enters the engine from the air filter not trough the carburater because the carb has only one gasoline  input ,so he removes the gasoline pipeline and the engine is running on cng and hho.Untill i see the engine runing without the big container in the back i maibe believe
geenee
« Reply #9, on July 31st, 2013, 01:34 AM »Last edited on July 31st, 2013, 01:42 AM by geenee
he proof infront of many PHD man,many TVs and president.no fraud people can do all of this.if he does then he go to jails.he don't use 12 dc to cell,he told maginify to 100volt and have a little box before wfc,please look it carefully.
adys15
« Reply #10, on July 31st, 2013, 01:47 AM »
I can also make a 20plate electrolizer ,take a cng car stuck the hho hose in the fuel line and demonstrate that the engine runs,it just takes 100$ and a lot balls to show my crap ''invention''on a tv show ,a cng engine is no real proof,if i see that engine runing on the ground with just one hose then i believe
AHL
« Reply #11, on July 31st, 2013, 02:04 AM »Last edited on July 31st, 2013, 02:34 AM by AHL
LMAO, what a fraud, ive seen much higher lpm fail to run a car. He was producing bugger all. Somehow i doubt its true. Resonance in a plate cell does NOT work like  a tube cell, completely different.
Here is resonance (sound) on a square plate, https://www.youtube.com/watch?v=1yaqUI4b974
and this is on a round plate, https://www.youtube.com/watch?v=CGiiSlMFFlI as you can see, while both plates, the round shape is what is needed to create meyers style resonance, this is my understanding anyway, i might be wrong, but i do not beleive this Pakistani man made the car run on HHO alone. Its been said that you need 1lpm for every 10 cc, personally i think its a littler lower than that but nevertheless, if the car was a 1600 cc and its probably much larger, he would need 160lpm just to idle it. He said it was about 8lpm. Sorry, i just cannot beleive this on a unmod engine running of a crappy battery only. Capacitor resonance is not meyer resonance, meyers was stepped, a capacitor cannot step, it pulses, thats only half of what you need in a resonant cell. Not once did the car backfire, and it should have if it was running unmodified on only HHO, cng was obviously present because the cng retards the hho flame speed cancelling out any backfiring. Also when the host asked if the cng was disconnected, he failed to answer the question. My 2c worth :)
geenee
« Reply #12, on July 31st, 2013, 03:39 AM »Last edited on July 31st, 2013, 03:56 AM by geenee
First i dont believe about free energy cause education dont want you think outside a box,a rule.like pakistan man he's looking poor but he told about meyer tech,all along meyer tech.no electrolyte, high volt,resonant,distilled water---->higher energy than tap water(from Meyer's table).
believe me,he do it and still alive.
AHL
« Reply #13, on July 31st, 2013, 04:00 AM »Last edited on July 31st, 2013, 04:18 AM by AHL
Quote from geenee on July 31st, 2013, 03:39 AM
geenee, no disrespect mate, but this is what about 20 lpm looks like, https://www.youtube.com/watch?v=wY9XPSOKoaA now look at how much wattage he needs to use and look at the size of the cell. Now if he could run a car with that, he would. And 12 volt is NOT high voltage btw. Just sayin, :)
geenee
« Reply #14, on July 31st, 2013, 04:51 AM »Last edited on July 31st, 2013, 05:36 AM by geenee
in first video,he show his cell and dry cell of professor.compare two types.lpm of that equal,about 2-2.5 lpm.but Agha's cell can idle engine with 2-4 lpm.in Meyer's table,dry cell with electrolyte = salt water then energy lower than distilled water if same lpm.
somethings can proof the fraud people is time.please look all videos.
attached picture for adys15.fruad man infront of PHD guy.PHD guy cannot tell hidden source.
AHL
« Reply #15, on July 31st, 2013, 05:07 AM »
Quote from geenee on July 31st, 2013, 04:51 AM
Meyers cell, i beleive made 55 lpm. It does not matter how Agha made his lpm, what matters is the LPM rate. 2-4 lpm can barely run an 86cc single cylinder let alone a car engine. Antway, if you believe it, than thats fine. Im just sayin is all. Its not good to have fraudelent ppl lying to the masses because in the end they get found out and this gives us guys like max, russ and mayer a bad name. So, have a nice day mate, and i hope you look a little more objectively into Agha's claims. Over and out :)
geenee
« Reply #16, on July 31st, 2013, 05:44 AM »Last edited on July 31st, 2013, 05:50 AM by geenee
Quote from AHL on July 31st, 2013, 05:07 AM
lpm don't tell energy inside gas.if gas have full of water(gas form) with little hho,this gas has low energy when you ignite it,it boom with little sound than hho gas without water(gas).
i'm sorry about my information if you don't like that.
attached picture is Meyer's table about energy yield(gtnt) of difference water.
AHL
« Reply #17, on August 1st, 2013, 12:11 AM »
Quote from geenee on July 31st, 2013, 05:44 AM
Anyway, i was just sayin, we all have opinions, ill let it go now. Hope you do well with your endeavors :)
geenee
« Reply #19, on November 8th, 2013, 04:24 PM »Last edited on November 8th, 2013, 06:03 PM by geenee
Quote from adys15 on November 7th, 2013, 12:01 AM
Told you that he was a fraud,and was using the cng gas
https://www.youtube.com/watch?v=yLjLA70NMKA
oil mafia sent him to jail or die.water power is always a fraud.
from video,cng pipe was plugged off.2nd demo tv show video.
at this time no one can make 2-2.5 lpm with distilled water like him.
from his facebook,he still sells his products at sep 2013.
https://www.facebook.com/pages/Agha-Waqar/295137617259754
