Beyond EPG
Circular Generator
Ok I came up this idea for a new style circular generator (not sure if someone already had this same idea?). Kind of like Stan Meyers EPG.
Generator # 1
As we know if a magnet is forced through the center of a coil of wire then a voltage is created. So my idea is to form plastic tubing into just one circle with multiple recovery coils applied all around the circular tubing just like Mr. Meyers EPG.
Inside the plastic tubing is a cylindrical neo magnet preferably attached to a non-magnetic carrier with roller wheels to reduce friction or one could apply a thin coating of oil to the inside.
One pulsing coil is turned on and attracts the neo magnet towards the coil and just before it enters the coil is turned off.
Note: spiracle neo magnets could be used with a carrier to keep them oriented in the right direction.
There needs to be enough momentum in the magnet to make it go around the circle and return to attraction coil. Potential problems could be that eddy currents in the generation coils would slow down the magnet too much.
Generator # 2 would be to have multiple magnets preferably attached to a non-magnetic carrier or the oil thing inside the plastic tubing circle that are magnetically coupled to other magnets attached to a spinning- wheel inside the diameter of the circle.
Considering the generation coils are air coils I think there would be less drag then normal iron core coils.
Additional ideas or thoughts to the validity of this type of generator are welcome.
It’s much like Stan Meyers EPG except no gas or liquid and only one loop of tubing.
element 119
Circular Generator
Generator # 1
element 119
