3D Printed Abha Torus
FractalVortex
« on June 29th, 2012, 12:46 AM »
First of all, I want to say hey again to Russ. I posted on some of his videos awhile ago when he was in the first days of his Stan Myers research. I then came across his designs linked on Thingiverse.com when looking for more Rodin Coil/Math research. I then found this great forum and am very happy to see Russ getting into the 3D printing side of things.
I just finished construction of my RepRap Prusa which has been a very challenging and fun project. As anyone who has built a 3D printer, there are so many things that can cause bad quality results. One application I am happy to see being explored is a 3D printed ABHA torus (which originally brought me here).
Here is the idea for a brand new construction approach. I would absolutely love to see a perfectly 3D modeled of all the complex number matrix pathways. With 3D printing here and now, lets go all in to build the best abha torus ever. One print material is porcelain/clay of sorts. Also, this might be a design best outsourced to shapeways for best results. The abha torus would show all the number triangles in a mesh structure.
The second stage would be another HUGE difference, Aluminum foil tape ;-). All other designs have used wire, this method would create a variable surface area, perhaps increasing effects. The "number diamond" areas would be covered in a conductive surface to completely incorporate the energy flow with the important geometry. The energy will literally be bent and warped, unlike wire designs. The energy curves but still has more straight lines. A lot of fantastic Rodin coil/ABHA Torus claims have been made, "no need for insulation", "levitation", "time portal", "flux capacitor". Generally speaking, the only changes have been in the number of windings, size, ratio, etc. This represents a new method to better tap the "eternal power source".
RE: 3D Printed Abha Torus
« Reply #1, on June 29th, 2012, 03:13 AM »
Quote from FractalVortex on June 29th, 2012, 12:46 AM
hey there!
check it:
http://open-source-energy.org/?tid=575&pid=5981#pid5981
http://open-source-energy.org/?tid=575&pid=6046#pid6046
all good stuff!
welcome!
« Reply #2, on June 29th, 2012, 12:45 PM »
Good to see another printer built here at the forum, that makes a total of five running printers, all Prusa's. To anyone wanting to build a printer, I have uploaded videos on how to build one and more videos to come, to finish the project, 1 through 7.5 here
https://www.youtube.com/user/nadingjeff?feature=mhee
and here are all the links to buy parts to build the printer, here
http://open-source-energy.org/?tid=376
Enjoy, Jeff.:cool::D
« Reply #3, on June 29th, 2012, 05:13 PM »
Welcome to the forums,
Designing more accurate ABHA tori to print out is definatly on the list of future "to-do's".  The one I designed for the pulse motor was a simplified version so I could have a chance to finish in time for the build off.:D  I probably won't be drawing another one untill the next pulse motor build off though.  Now that I've done it once, it's just more time consuming and tetious, rather than hard to draw.  There really will be no limitations on the types of coil formers we can make in the future.  That was the original reason I got so interested in RepRap when Jeff introduced me to it. :cool:
As for all the claims that a Rodin coil can do, I think a person has to understand how the universe works before any of those can become a reality.  Rodin coils have proven to reduce current draw in certian situations.  Definately a lot for us to learn.
Also check out the 3D files posted in this section, lots of stuff there that isn't on Thingiverse.  http://open-source-energy.org/?fid=48
