Jon Able's videos, has resonance on his cell
adys15
RE: Jon Able's videos, has resonance on his cell
« Reply #26, on January 15th, 2013, 02:33 PM »
Quote from Jeff Nading on January 15th, 2013, 12:13 PM
Quote from adys15 on January 15th, 2013, 12:02 PM
Hy guys,here is the skematic Jon posted on Garry's blog....hope someone has beter luck then me on it...thanks verry much Jon!
Thanks  adys15, looks doable.:cool::D:P
You are welcome Jeff,yes it looks doable but if you wind all the coils with bare hands ,like i did it will take about 4 hours,and painstaking patience.I'v wound them by hand because i couldn't find a perfect fit bobin for my core ,but i made every wind perfect...I also matched Jon's  bifiliar resistance(1.2ohm each)...All in all the output was only 2v from 12 input...don't know why...
« Reply #27, on January 15th, 2013, 02:58 PM »
Quote from adys15 on January 15th, 2013, 02:33 PM
Is your cell like his or is there a way to tell, would make sense to me if their not the same you would see different results.:D
adys15
« Reply #28, on January 15th, 2013, 03:02 PM »
Is your cell like his or is there a way to tell, would make sense to me if their not the same you would see different results.:D[/quote]I was refering at the voltage output of the transformer,no cell atached,at 2v is no use...My cell is 3 inch tall,1mm spacing..
« Reply #29, on January 15th, 2013, 03:09 PM »
Quote from adys15 on January 15th, 2013, 03:02 PM
I was refering at the voltage output of the transformer,no cell atached,at 2v is no use...My cell is 3 inch tall,1mm spacing..[/quote]Then I wonder if the circuit should be completely connected for it to work properly, I could be all wet, don't know for sure.:D
adys15
« Reply #30, on January 15th, 2013, 03:13 PM »
Then I wonder if the circuit should be completely connected for it to work properly, I could be all wet, don't know for sure.:D[/quote]Tried of course and meter shows 00.00
I dont have a real scope...just a soundcard one...so i dont know whats realy happen
« Reply #31, on January 15th, 2013, 03:19 PM »
Quote from adys15 on January 15th, 2013, 03:13 PM
I dont have a real scope...just a soundcard one...so i dont know whats realy happen[/quote]Hey adys15, in the link you posted I noticed john's email address, you might try to email him to pick his brain a little, maybe he can shed some light on whats happening, it would be worth a try.:D
adys15
« Reply #32, on January 15th, 2013, 03:26 PM »
Hey adys15, in the link you posted I noticed john's email address, you might try to email him to pick his brain a little, maybe he can shed some light on whats happening, it would be worth a try.:D[/quote]Thanks..I talked to him a while ago on F.B.and told me about  what you guys know from his videos,and what is the pdf ,no secrets,Joh wants from all his heart to help people,it is a very honest and helping person!...
« Reply #33, on January 15th, 2013, 04:13 PM »
Quote from adys15 on January 15th, 2013, 03:26 PM
Thanks..I talked to him a while ago on F.B.and told me about  what you guys know from his videos,and what is the pdf ,no secrets,Joh wants from all his heart to help people,it is a very honest and helping person!...[/quote]Ok, could he help in your efforts to make yours work?:D
adys15
« Reply #34, on January 15th, 2013, 04:32 PM »
I dont know,i think so,he is hard to reach,he helped me alot, gave me all the info he could,parts that he used...i asked him all i could ask....
I also need others to try Jon's setup and share scope shots because i dont have one and i need to see what others are seeing...Most of us has the Dave lawton pwm already build so only the simple transf needs to by wound,if you wind your coils with a coilwinder is done in an hour....why no one is building Jon's  working simple setup,and spend days on developing formulas for calculating capacitance...inductances....programs....why spend 3days calculating  what is the resonant freq ,when you can build the setup find if is working or not....Just my thought...no ofense...i was refering in general...
« Reply #35, on January 15th, 2013, 04:46 PM »
Quote from adys15 on January 15th, 2013, 04:32 PM
I understand. It's like finding a needle in a hay stack, so that's why we are trying to do it by the numbers. Hopefully doing it this way, with the really smart guy's that are on it right now,:cool::D:P we will hit pay dirt.
