ideas on how difficult to find pressure rated aluminum tube is?
source of aluminum pressure tube, copper, magnets & plasma emitters?
tracking stuff down since the technology all works & is viable.
sealed plasma cylinder, aluminum (non-magnetic because the piston is magnetic)
plasma arc in cylinder, magnetic piston & arc drives transformer windings wrapped around cylinder.
combines Josef Papp & Stan Meyers ideas.
use Tesla type transformer, then trigger plasma arc inside the transformer coil with the emf generated.
should induce higher output than expected.
"lightning in a bottle" seems to step up the current & voltage simultaneously.
dudes were genius', but missed that plasma trapped would expand plus boost emf power too.
with plasma cutting, gas mig / tig, gas pressure during plasma phase is high plus carries both voltage & current.
Papp & Meyers ideas each used plasma to generate power, just not in a closed cylinder described this way with a transformer wound around the cylinder itself.
tracking down parts & building a piston with krytron magnets for a small test engine.
figured y'all would enjoy, as it's a simple engine mechanism.
just a sealed chamber with arc gas in it.
arc emitter where the head would be & electrode side on the piston surface.
arc pressurizes gas, transmits flux to coil.
magnet & plasma arc both push flux into the transformer wrapped around the cylinder.
no moving valves, just the plasma arc & magnetic pulse at TDC that pushes the piston down.
[attachment=1761]
[attachment=1761]
