Laser pointer to burning laser mod.
RE: Laser pointer to burning laser mod.
« Reply #1, on June 5th, 2012, 08:54 PM »Last edited on June 5th, 2012, 09:05 PM by Jeff Nading
Quote from Robert Twiss on June 5th, 2012, 06:00 PM
https://www.youtube.com/watch?v=9Hab3tAQaVA
Here's one from a DVD burner, RED, maybe it could be used in the gas gun.
https://www.youtube.com/watch?NR=1&v=x1ju_4hbblE&feature=fvwp
This is also very interesting, of course the last couple vids are salvage projects.
https://www.youtube.com/watch?v=IyGks86UAQs&feature=related
Hi Robert, I have built three different lasers, two from dvd burners red and blue, then a green one from a laser pointer, they all burn.
https://www.youtube.com/watch?v=bQWx-7lH8ec&list=UUJYJgj7rzsn0vdR7fkgjuIA&index=6&feature=plcp
https://www.youtube.com/watch?v=lE3F7vjYx4U
https://www.youtube.com/watch?v=_VrNDe9mpOs&list=UUJYJgj7rzsn0vdR7fkgjuIA&index=5&feature=plcp
Build a laser diode driver using a LM317
https://www.youtube.com/watch?v=BI7iuBze5I8
https://www.youtube.com/watch?v=2Rjlf7gnXms
you can buy drivers here,
http://rkcstr.nfshost.com/index.php?main_page=index&cPath=65
Enjoy.:D:cool::P
Robert Twiss
« Reply #2, on June 6th, 2012, 04:43 AM »
Great videos Jeff, it appears you are a fire bug.
I guess my point is, that unless the laser can burn, it's just a bright light.
I was just thinking about the gas gun.
I know Russ is great at reverse engineering Stan's work and the one he built is probably accurate as it gets, but they are not real lasers.
And in reality these lasers, laser diodes, are not real lasers.
The core of a real laser is a crystal that has a xenon flash lamp wrapped around it.
the crystal polarizes the light and gives it a linear path.
The Laser Diode is a bright light in front of tiny magnifying glass.
But this actually could better than an actual laser for a gas gun application because it can be focused to a point inside the gas gun at an intensity below vaporization unless you want steam.
Point one of your lasers into a cup of water, see what happens.
« Reply #3, on June 6th, 2012, 04:58 AM »
Quote from Robert Twiss on June 6th, 2012, 04:43 AM
I have pointed one into a glass of water, also into my cell while producing HHO, nothing appears to happen.
Robert Twiss
« Reply #4, on June 6th, 2012, 05:08 AM »
You didn't see steam in the water?
And remember, you can't see anything at the molecular level.
Also the gas gun has a couple dozen lasers.
Robert Twiss
« Reply #6, on June 6th, 2012, 05:54 AM »
That must mean that the water diffused or refracted the laser light.
That still doesn't mean that the electrons weren't stimulated, it just wouldn't be obvious to the human eye.
It may also mean that the water may not get hot or over heated either.
« Reply #7, on June 6th, 2012, 06:19 AM »
Quote from Robert Twiss on June 6th, 2012, 05:54 AM
I think it's all the above and more. Don't have the right test equipment to prove or disprove any of this though.
Robert Twiss
« Reply #8, on June 6th, 2012, 12:31 PM »
Quote from Jeff Nading on June 6th, 2012, 06:19 AM
Thanks for engaging me in this.
It seems you spent some time on this.
« Reply #9, on June 6th, 2012, 01:09 PM »
Quote from Robert Twiss on June 6th, 2012, 12:31 PM
Yes it was about 4 years ago, for my cnc plasma cutting machine, the lasers I built were not powerful enough to cut with though, just an experiment.:cool::D
Robert Twiss
« Reply #10, on June 6th, 2012, 04:34 PM »
Quote from Jeff Nading on June 6th, 2012, 01:09 PM
I saw a few of the CNC machines, cutting mostly balsa.
« Reply #11, on June 6th, 2012, 04:40 PM »
Quote from Robert Twiss on June 6th, 2012, 04:34 PM
Yes, I wanted to cut plastic, wood and metal:D.
Robert Twiss
« Reply #12, on June 6th, 2012, 04:48 PM »
Quote from Jeff Nading on June 6th, 2012, 04:40 PM
You know that they use water to cut with?
« Reply #13, on June 6th, 2012, 05:50 PM »Last edited on June 6th, 2012, 05:51 PM by Jeff Nading
Quote from Robert Twiss on June 6th, 2012, 04:48 PM
Oh yes, one water jet cnc machine used, is over 100 grand, the plasma machine I built was about 12,000 with my labor, maybe more.:D
