The current setup is a few steps something like these;Quote from Casper on August 30th, 2011, 03:34 PM Hey, bear with me please... How can i get this code into my arduino mega?
Casper
- Get Arduino IDE working. (http://arduino.cc/en/Guide/Windows)
- Create "PulseFire" sketch. (with the capitals)
- Close Arduino ide
- Download PulseFire 0.9-fix from forum
- Unpack PulseFire and move/copy all the *.pde/*.h files into the directory
where the PulseFire sketch is. (I think "My Documents\sketechbook\PulseFire")
- Start Arduino IDE, select sketch and compile/flash into Arduino.
- Possible tweak IO settings in "vars_define.h" and flash again.
- Download PulseFire-UI from forum
- Unpack PulseFire-UI and run pulsefire.exe or run.bat
The 0.9-fix download is in this post; http://open-source-energy.org/?tid=56&pid=910#pid910Yeap is almost time for that :) I wanted to do that when arrived at 1.0 or when release plugin is configed so it will be automaticly uploaded to distributed release servers on http://download.savannah.gnu.org/releases/pulsefire/Quote from Casper on August 30th, 2011, 12:38 PM What do you think about making a separate thread for the pulsebox software? that way new releases will be gathered in a nice structured list.Yes, for realtime changes need to add some event listeners to the settings to support that.Quote from Rwg42985 on August 30th, 2011, 04:54 AM to make it work i got to check the color. then close out and open it back up and then it works. is that right?
Casper
RE: EPG Testing sequential pulsar using the Arduino
« Reply #175, on August 31st, 2011, 04:49 PM »
