@ txqNL: Will you be releasing your arduino software program?
Big Up's to txqNL on your new arduino interface. I had a peek on Russ' live feed and it looks totally sick. Cant wait to try it sometime !! I am working on learning the code... but it is extremely time consuming...
My Russ G Replica box :)
Link to the newest sketch? I should have driver coils ready tonight and want to use the pulse fire to run the motor. I am sure I will have some questions, but first I need the sketch.
Peace
rawbush
is latest version .8 ?
Info for all
Enjoy CaptBay
I am in search of an open source software for open source manufacturing, I have heard that these days ERP is very much famous for getting the better outcomes in open source. Is it true?
(Windows 32 and 64 bit)
(Linux 32/64,macosx,windows32/64)
This is the first GUI release which only connects to PulseFire version 0.9.
I only tested on, so hope others are also working;
-Linux 64 bit (Debian amd64)
-Windows 32 bit (Vista)
Cheers,
Willem
Does it work correct for everybody ? No bugs, features or other questions ?
Found one bug in the external triggering which restart the pulse train when next trigger comes I would like to skip until full pulse is finished, but both options are valid so have to make it a feature/option.
The B&W version 'fixed' the colors :P
Will check into the trigger code this week asp have the same problem with single hall sensor feedback.
Some small fixes in gui;
- Made application settings work
- Created simple data log outputs for measurements and moved to settings tab.
- Added setting for color schema currently 3 supported.
- Fixed console layout and enabled input field.
- Fixed automatic graph display over info after connect.
- Note: all settings work but only after application restart !
Hey, bear with me please... How can i get this code into my arduino mega?
Casper
What do you think about making a separate thread for the pulsebox software? that way new releases will be gathered in a nice structured list.
to make it work i got to check the color. then close out and open it back up and then it works. is that right?
Casper
