I looked at all of the estate photos, and this what I was able to come up with. Hope this helps.
OMEGA Engineering, INC (Top of WFC Pressure Transducer P/N PX176-050A5V)
One Omega Drive
http://www.omega.com
P.O. Box 4047
Stamford, Connecticut 06907-0047
800-622-2378
http://www.omega.com/pptst/PX176.html
P/N PX176-050A5V 0-50 PSIA pressure transducer with 36" cable
(FROM: ESTATE PHOTO: WFC/_ICT0014.JPG)
Magnetics Inc (Ferrite E-Core #OP48020)
http://www.mag-inc.com/
110 Delta Drive
Pittsburgh, PA 15238-0428
1-412-963-9363
http://www.mag-inc.com/home/Advanced-Search-Results?pn=48020
(FROM: ESTATE PHOTO: IGNITION COIL/DSC_0234.JPG)
Superior Electric (Variac/Rheostat for Pulse Generator/Pulse Voltage Generator)
http://www.danaherspecialtyproducts.com/Superior_Electric/
383 Middle Street
Suite 105
Bristol, CT 06010
(800)-787-3532
Type 21 PowerStat Variable AutoTransformer, 0-140V, 5.0A, 0.70 KVA
http://www.danaherspecialtyproducts.com/Content.aspx?id=5279
(FROM: ESTATE PHOTO: ELECTRICAL POLARIZATION & ROTARY PULSE GENERATOR/PICT0053.JPG)
http://www.alliedelec.com/search/productdetail.aspx?SKU=70120679
Shurite / Prime Technology Model 850 Panel Meter 0-150VDC (Volt Meter for Pulse Generator)
http://www.primetechnology.com/PartsDetails.aspx?PartsId=188&Parentid=86&ParentType=C
Prime Technology
344-352 Twin Lakes Road
North Branford, CT, USA (203) 481-5721
850 Series 0-150VDC Extact replacement (Shurite 8115Z), from Allied Electonics:
http://www.alliedelec.com/search/productdetail.aspx?SKU=70136692
(FROM: ESTATE PHOTO: ELECTRICAL POLARIZATION & ROTARY PULSE GENERATOR/myers pics(123).jpg)
Simpson Panel Meters (Hydrogen Fracturing Process Generator)
Simpson Electric
http://www.simpsonelectric.com/index.asp?p=Products&id=18&sid=19
520 Simpson Avenue
Lac du Flambeau, WI 54538-0099
Phone: (715) 588-3311
0-150VAC
http://www.alliedelec.com/search/productdetail.aspx?SKU=70209378
0-100 Amps
http://www.alliedelec.com/search/productdetail.aspx?SKU=70209374
(FROM: ESTATE PHOTO: GENERAL/DSC_0203.JPG)
Crydom Relays P/N A1240 (Back of Hydrogen Fracture Process Generator)
http://www.crydom.com/en/index.shtml
2320 Paseo de las Americas,
Suite 201
San Diego, CA 92154
1 (877) 502 5500
From Allied: http://www.alliedelec.com/search/productdetail.aspx?SKU=70130413
(FROM: ESTATE PHOTO: GMS/DSC_0201.jpg)
T.E. Connectivity/AlcoSwtich (part of Tyco Electronics now) - GMS CARDS
http://www.te.com/catalog/menu/en/21109
MRC11004 10 Position Rotary Switch
From Allied: http://www.alliedelec.com/search/productdetail.aspx?SKU=70155953
(FROM: ESTATE PHOTO GMS/
Honeywell 392JA Series Potentiometers - GMS CARDS
25K Pot: http://www.alliedelec.com/search/productdetail.aspx?SKU=70153327
50K Pot: http://www.alliedelec.com/search/productdetail.aspx?SKU=70153328
100K Pot: http://www.alliedelec.com/search/productdetail.aspx?SKU=70153329
(FROM: ESTATE PHOTO GMS/PICT0021.JPG)
Miyama/Mountain Switch Toggle Switches - MS166 and MS550F (Japan) - GMS CARDS
MS166 SPDT ON-ON 10A.125V.AC, MS550F DPDT ON-ON 3A.125V.AC / 1A.250V.AC
http://www.federalcomponent.com/miyama_toggle%20switch.htm
Sold as "Mountain Switch" at Mouser
(FROM ESTATE PHOTO GMS/PCT0025.JPG)
Bourns 3006 Series 10K TrimPot for GMS Cards:
http://www.bourns.com/ProductLine.aspx?name=trimming_potentiometers_multiturn#3006
From Allied: http://www.alliedelec.com/search/productdetail.aspx?SKU=70153559
(FROM ESTATE PHOTO GMS/PICT0021.JPG)
KNOBS
Looks very close to the original knobs for GMS Cards:
Apem Dimond Knurl Aluminum Conrol Knobs
http://www.apem.com - Series 42003
63 Neck Road, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890
http://www.mouser.com/ProductDetail/Apem/420033B14/?qs=0WSWfj%252btgBYxpTqnqFDWe7MLMRBE8mgT%252b%2f6fRh4aSKA%3d
(FROM ESTATE PHOTO: GMS/PCT0025.JPG)
AmazingMagnets - FerroFluid 1000Ml EFH1
Also Neodyimum and Rare Earth, Bar Magnets, ball bearingss, and Steel Discs
http://www.amazingmagnets.com/
http://www.amazingmagnets.com/show-decimal-ferrofluid-1000.aspx
(FROM ESTATE PHOTO: HOME AND HEATING & EPG/DSC_0013.jpg)
GC Electronics Silicone Rubber Adhesive Sealant (Next to EPG)
From Allied: http://www.alliedelec.com/search/productdetail.aspx?sku=70159773
(FROM ESTATE PHOTO: HOME AND HEATING & EPG/DSC_0016.JPG)
Radio Shack 12.6V 3 Amp Secondary Transformer (On EPG BOARD) P/N 273-1511
http://www.radioshack.com/product/index.jsp?productId=2102702
(FROM ESTATE PHOTO: HOME AND HEATING & EPG/DSC_0054.JPG)
Parker Hannofin (connectors, fittings, hoses) P/N "4-5 F5OX-SS" (Box of connectors next to WFC Case - WFC Fittings?)
http:/www.parker.com
Parker Part Number 4-5 F5OX-SS
Straight Thread Connector Stainless Steel 1/2"-20 with O-ring
http://www.parker.com/portal/site/PARKER/menuitem.bb22d5a82bbb5b147cf26710237ad1ca/?vgnextoid=a2d9b5bbec622110VgnVCM10000032a71dacRCRD&vgnextfmt=EN&vgnextcatid=2638969&vgnextcat=F5OX%20STRAIGHT%20THREAD%20CONNECTOR%20STAINLESS%20STEEL&vgnextdiv=687620&vgnextpartno=4-5%20F5OX-SS&Wtky=
(FROM ESTATE PHOTOS: IGNITION COILS/DSC_0234.jpg)
**(NOTE: These look like the fittings from WFC/_ICT0023.JPG on the BOTTOM OF THE WFC)
Jenco Electronics is supposed to have the WK-S22A2T connector
http://www.jencoelectronics.com/
The round ones look like regular Amphenol connectors.
(FROM ESTATE PHOTOS: VIC CARD AND ASSY/_ICT0010.JPG)
Ashcroft 0-15PSI, 0-100kpa dual scale model 1008 Stainless Steel Pressure Gauge (Gauge on Demo WFC)
Gauge P/N 1008SL2.5
http://www.ashcroft.com/products/pressure_gauges/steel/Types-1008S-Gauges.cfm#
From ColeParmer - http://www.coleparmer.com/buy/product/5164-0-15-psi-0-100-kpa-dual-scale-gauge-bottom-connection.html
(FROM ESTATE PHOTOS: WFC/PICT0074.JPG)
One Omega Drive
P.O. Box 4047
800-622-2378
110 Delta Drive
1-412-963-9363
383 Middle Street
Suite 105
Bristol, CT 06010
(800)-787-3532
Prime Technology
Simpson Electric
520 Simpson Avenue
0-150VAC
0-100 Amps
Suite 201
San Diego, CA 92154
1 (877) 502 5500
KNOBS
Gauge P/N 1008SL2.5
