https://www.youtube.com/watch?v=KUfRRQXAvYE&feature=relatedit is important to note that the original videos, show not additives not mixing,
you have to watch very carefully what they are showing is that even with detergetnt not bubbles are allowed to form or are controlled to be so small they are micro Nano bubbles. now these guys are getting things to run
even when moving the saturated liquid to tanks.
Imagine not trying to move it but injectit straight to chamber via stans system
would it work , with out current knowledge ?
The video particulary older ones fromOHMASA GAS clearly show hydrogen and oxygen released by electrolyser is shaken not stirred back into the water and not escaping as bubbles this is very interesting, way to approach it is immediately debunk all hho gas strategies as trying to control the gas with open air or bubbles now look to be wrong way
to compare to stans staged system. connect the 2 or look closer at stans final discoveries particulary the quenching tube to injector. this would keep the
ohmasa gas in solution right to the injector.
Just apply knowledge for a moment
water tank = steam =vibraton= wfc= quenching tubes to injector
final squeeze and volatge. ( all in matter of seconds)
would h2o in OHMASA GAS saturated form work much better if applied in stans system,? "dam right it would. "
If your excited,
go through
right click and save every page in the forum to you hard disc now.
an use download help to save videos from you tube
and start building
find something to help with today and post it or make it .
Stuff happening. get on it.
Dan.
