My Spiral Cell Mockup
Robert Twiss
« on May 20th, 2012, 01:16 PM »
This is my initial mockup.
The holes are smaller than they are supposed to be and I used 14 ga wire to get an idea of where I'm going with this.
I still have some spacing and configuration issues.
Keep in mind that the finished product will be 1/4" stainless steel tubing.
[attachment=1448]
[attachment=1449]
[attachment=1450]
Robert Twiss
RE: My Spiral Cell Mockup
« Reply #1, on May 20th, 2012, 02:39 PM »
After some serious examination, the sweep of the rear section is way to steep.
Goes to show, making an inexpensive model saves $$$.
Back to the drawing board to change the spacing.
Robert Twiss
« Reply #2, on May 20th, 2012, 07:20 PM »
The reason I'm having trouble with spacing is because I'm using standard pipe dimensions to wrap 1/4" tubing with.
Inadvertently, I'm getting conical spirals because I have to space it to eliminate integrity issues. So of course I'm curious.
The 14 ga is just because it's easy to work with, when I'm satisfied with the spacing I will use some seriously heavy gauge solid copper for a better look. I will more than likely energize it at this point to see how it acts.
If I like what I see, I'll go for the 316 welded tubing.
I'm shooting for 3-4 of these cones in only 8"
This configuration will allow me to test a number of configurations.
1). Seperate Hydrogen and Oxygen, 1 pos or neg with 3 close neutrals.
2). Pos and Neg with 2 neutrals x 2 cells, HHO
3). 2 Pos and 2 Neg x 2 cells, HHO
I'd love to believe it would create a vortex, but the board, which represents Lexan(R) is a baffle so that's out.
Robert Twiss
« Reply #3, on May 21st, 2012, 06:43 PM »
OK, I believe I have spacing worked out now and should be able to create 4 conical spirals in 8".
All further postings of this project will be in the Projects area.
« Reply #4, on May 21st, 2012, 11:17 PM »
sweet!
that's crazy! lol defiantly better to build a cheaper one to test with!!! :)
