9 cell water capacitor
« on April 12th, 2012, 11:54 AM »Last edited on May 13th, 2012, 05:26 PM by ~Russ/Rwg42985
Water Fuel Cell Theory
Making a Real Water Capacitor with the Stanley Meyer (WFC)
Using plates or tubes in tap water:
 one can find the original data here:
http://ritalie.com/water_fuel_cell_theory.htm
Contrary to Meyer’s explanation, water is NOT the dielectric. This is one stumbling block that confuses many people. For all practical purposes, there is no such thing as useful "dielectric water." Only ice can be a true dielctric. Nikola Tesla discovered that ice was an extremely good insulator, and yet ice has often been measured to have a higher dielectric constant than liquid water.
"Because ice and water have strong molecular dipole moments, the dielectric constant for both water and ice is approximately a value of 80 at "low" frequencies (up to approximately 400 Hz for the temperature range shown here). The water dielectric constant stays nearly constant for greater frequencies due to the characteristic orientation relaxation frequency being above 1000 Mhz. In contrast, the ice dielectric constant starts falling off rapidly at frequencies above approximately 400 Hz because of a much lower characteristic orientation relaxation frequency.."
"...the dielectric constant and conductivity of liquid water are nearly independent of frequency for values less than 1,000 MHz. " (Frequencies less than 1,000 Mhz will not have an effect on the water molecule.)
http://www.freepatentsonline.com/6239601.html -- Weinstein, Leonard M. (Newport News, VA)
Liquid water will have a small capacitance, but mainly it is just seen as a resistance! A true dielectric has to be a pure insulator.
True capacitors have very thin dielectrics. You cannot have a true capacitor with a 1/16” gap between the two plates, because the capacitance of any given dielectric decreases exponentially with distance, therefore the large gap between the plates in a WFC cannot possibly provide any useful capacitance. Try taking your two stainless steel plates and stuffing a thin sheet of dielectric (non conductive) dry newspaper between them. Now try measuring the capacitance between the two plates. It won’t be much, if anything. That is because thick dielectrics do not perform well as a dielectric!
In a real water capacitor, and in many commercial electrolytic aluminum capacitors, water is used as a conductor, and forms an extension of the cathode, while the real dielectric is the microscopically thin oxide layer on the stainless steel (or aluminum) anode. The water conducts electricity, while the ultra thin oxide layer on the positive plate is an insulator. When you have a proper oxide coating, an extremely powerful capacitance exists only between the negatively charged water bath, and the positive plate. In contrast, the capacitance between the actual plates or tubes is incredibly tiny, because the plates or tubes are simply spaced too far apart. The real capacitor is formed at the oxide layer.
This oxide layer is what makes a given water capacitor perform like a real capacitor, behaving in a way that is beneficial and even mysterious. For example, a functioning water capacitor stores static electricity momentarily after it is disconnected, because there is very little internal resistance. I’ve made real water capacitors using aluminum plates in baking soda. Immediately after being disconnected from power, they can be discharged violently with a tremendous spark. This only happens if you have a non-conductive oxide formed on the positive plate/s. Before the oxide is formed, the capacitor will not take a charge and hold a charge.
Aluminum oxide doesn’t have the same properties as the oxide that forms on stainless steel, so stainless steel is better suited to making hydrogen, though aluminum does make a very good capacitor in distilled water mixed with baking soda.
"The dielectric material of electrolytic capacitors is produced from the anode metal itself in what is known as the forming or anodizing process. During this process, current flows from the anode metal – which must be a valve metal such as aluminum, niobium, tantalum, titanium, or silicon – through a conductive bath of a special forming electrolyte to the bath cathode. The flow of current causes an insulating metal oxide to grow out of and into the surface of the anode. The thickness, structure and composition of this insulating layer determine its dielectric strength. The applied potential between the anode metal and the bath cathode must be above the oxide breakdown voltage before significant current will flow."
(The type of metal used in a water capacitor is obviously important, in one of his lectures, Stanley Meyer said that the invention of stainless steel is what actually made his process possible. If we take this statement at face value, than stainless steel must have decent electrical properties.)
http://electrochem.cwru.edu/encycl/art-c04-electr-cap.htm
A proper oxide coating is 100% non conductive, and extremely thin, perhaps even invisible to the naked eye.
In a water capacitor, the metal oxide forms the dielectric, not the water! The water carries current, and forms the anode. This is how water capacitors have been built all along, and that hasn’t changed.
Webmug
RE: 9 cell water capacitor
« Reply #1, on April 12th, 2012, 02:36 PM »Last edited on May 13th, 2012, 05:27 PM by ~Russ/Rwg42985
Quote from securesupplies on April 12th, 2012, 11:54 AM
Nice theory! Problem I have with your information is that a WFC does not use current. Dielectrical properties are the capacitance of the exciters as static voltage and the resistance that forms the RLC with the chokes (dual in line) to restrict amps. The capacitance is low say pf nf.
Br,
Webmug
« Reply #2, on April 12th, 2012, 02:54 PM »Last edited on May 13th, 2012, 05:27 PM by ~Russ/Rwg42985
Good explanation. I have a one cell, you can see the oxide that has formed on the inner SS tube. If I keep the amperage @ 1/2 an amp the oxide starts to form and build, if I crank the amperage up higher than 1/2 an amp the oxide starts to flake off and disintegrate.
geenee
« Reply #3, on April 12th, 2012, 04:55 PM »Last edited on April 12th, 2012, 04:59 PM by geenee
i think if dielectric is very thin
watermolecule cant enough elongate  to split to hho because waterbath(H2O is bigger that gap) cant insert between positive iron oxide and negative charge oxygen ion
if air gap capacitor can work then water gap can work too but it able to leak electron or another word is "amps flow"
u can fix this problem by using low voltages.
but Stan use high voltage .i think exciter is water capacitor form or very high positive electrostatic form but cant able to stop amps flow but can restrict amps flow(input amps) at gate time(stop power) but in gate time amps(electron) able to flow to high positive electrostatic plates ---> electron from liberating electron from waterbath because positive plate still have high positive electrostatic
supermuble
« Reply #4, on May 12th, 2012, 09:47 PM »Last edited on May 12th, 2012, 10:08 PM by supermuble
Hi guys. So I am reading this page, and found it fascinating. Then I realized it's directly copied off my website! That's good, except there is no mention of my website anywhere. I didn't copy that information on my website, I wrote it word for word myself, after doing my own tests. I'd at least like some credit! Smile So I couldn't help it, I had to chime in. I own http://www.Ritalie.com. Nice to meet you guys! My capacitor information might be the only simple explanation of a water capacitor on the internet, since I searched and searched and came back to the information I wrote originally a few years ago! Sad that more people haven't figured out water capacitors and done more tests.
Here is my actual web page, that I wrote, about water capacitors. It's got most of the same information that was posted here already. http://ritalie.com/water_fuel_cell_theory.htm
I did all the tests on aluminum capacitors and made a Youtube video of it here: http://youtu.be/JL0WE5zZXgQ
VERY IMPORTANT: Notice that I have over 200 volts going to my aluminum water capacitor, with NO current going to the water, and there is ZERO hydrogen production. Obviously, a water capacitor does not automatically equal high volumes of HHO gas, nor can you force current through a capacitor and get large quantities of gas, because it instantly ruins the capacitor by breaking down the oxide layer. Now, it is possible that "dielectric breakdown" of certain valve metals (not stainless steel) could produce hydrogen while also maintaining a very high voltage, but I've not found that metal, nor has anyone else, at least not publicly. Meyer saying that Stainless Steel was a water capacitor, is just simply wrong, because 304L & 316L does NOT form a powerful water capacitor with tap water, because stainless is NOT A VALVE METAL. Valve metals form "diodes" on the surface of the metal, by producing a non conductive oxide (like Ruby, which is also known as aluminum oxide, which is what forms on aluminum.) Stainless steel forms a resistive oxide, but it's not a "non conducting" oxide, and there is a big difference. A stainless water fuel cell is a big resistor, with no useful capacitance, because the resistance is too low, and nullifies the useful capacitance, so that the moment you disconnect it, the water conducts energy across the plates, electrons flow between the plates, through the resistive oxide, and you lose all the voltage you just put in. This isn't a capacitor in the true sense of the word.
I guess we need to take this farther!
« Reply #5, on May 13th, 2012, 06:20 AM »
Quote from supermuble on May 12th, 2012, 09:47 PM
Yes, people should be giving credit for the sources of information posted here.
Webmug
« Reply #6, on May 13th, 2012, 06:40 AM »
Hi supermuble,
When you charge a water capacitor and abruptly stop charging (GATING the PULSE) what will happen then?
Stan talked about resonant action by tuning the gate frequency on the gap-size between the exciters and restrict the current with the chokes at the same time.
This gating should break (shake) the weakened (charged NEG and POS exciters) covalent bonding of the water molecule.
For now it is a still a theory, but the VIC builders here are on it! Time will tell...:cool:
Thanks for joining the forum!
Br,
Webmug
« Reply #7, on May 13th, 2012, 05:25 PM »
hey there, i will address this issue and let others to all ways reference the data posted here.
thanks for being understanding about this!
OPEN source  is the key to our future!
sebosfato
« Reply #8, on June 28th, 2012, 12:38 PM »
Most of this information is wrong. I'm sorry to say. But water yes have a good capacitance greater than calculated value. You just need to know what you are doing.
lamare
« Reply #9, on September 3rd, 2013, 02:29 PM »Last edited on September 3rd, 2013, 02:52 PM by lamare
Very interesting. Need to study your stuff further.
However, what you need to do IMHO is to charge your capacitor with high voltage pulses, such that the dielectric gets super-polarized. That's  what Bedini-like chargers do, and elco's charged with these have been reported to spontaneously recharge, which means that the well known dielectric relaxation effect can be boosted. And, Bedini reported that lead-acid batteries charged with his chargers "cold boil" up to an hour *after* he shut the power off.
See my theory thread about how I think this works:
http://open-source-energy.org/?tid=1168
BTW, did some experiments a while ago, and I did get some gas production: https://www.youtube.com/watch?v=swknDdT05-M
It turned out at some point that my scope was not properly grounded and had a voltage from the 220V outlet at it's ground connection, which did not feel very comfortable when touching. That sometimes happens with not properly grounded equipment. I think that might have influenced my results, but it's a long time ago and I don't remember.
What I do remember is that the capacitor was very leaky. It would discharge pretty quickly. Perhaps there was too much impurities like dirt, etc. in there.
Here's a link about making electolytic capacitors:
http://rimstar.org/science_electronics_projects/make_electrolytic_capacitor.htm
There's more info in my theory thread, too.
Quote from Webmug on May 13th, 2012, 06:40 AM
Hi supermuble,
Br,
Webmug
That is a good point. The direction of polarization of the dielectric layer is opposit to the direction of the applied electric field. And since you get "the glow" - plasma forming within the water - when using essentially the same construction when building an old-school rectifier during the period of time when the electrolyte - dielectric - metal layer is in reverse, it is clear electric field generated by the dielectric is at it's strongest after a fast, sudden discharge of the capacitor.
And because the polarization of the dielectric depends on the applied field strength and not on any current, one needs to "charge" the capacitor with high voltage spikes.
The resonance which Meyer used is an acoustic resonance of the fluid in order to keep it moving and prevent gas bubbles to stick to the metal. He essentially uses his pipes as organ pipes, only submerged in water. And because the fluid is kept in a state of movement, gas production increases.
Heuristicobfuscation
« Reply #10, on September 3rd, 2013, 06:46 PM »
Is there such a thing as a "Perfect Capacitor"?
Does Stan Meyer Exiter array submerged in water produce a "perfect capacitor"?
Answer = No..
Did Stan Meyer condition his cell array
Answer= No
Did he condition the water fuel injector?
Answer=No
Does Stan Meyer technology work?
Anwer=Yes ...
how do i know? becouse we are all here trying to replicate this lost tech...we all are witneses to the amazing achivement of runing that dune buggy completly on water!
We dont need a "perfect capacitor" to replicate and acheive stans success!
lamare
« Reply #11, on September 3rd, 2013, 11:16 PM »
Quote from Heuristicobfuscation on September 3rd, 2013, 06:46 PM
Answer = No..
Answer= No
Answer=No
Anwer=Yes ...
How do you know Stan did not condition his cell array in any way? There's *always* some kind of dielectric layer present on stainless steel, aluminum and other so-called "valve metals". Was there some "work in" time needed or did the cells work right away after fitting things together?
Did the injectors actually ever work?
For all I know, after the first video wherein he demonstrated his car publicly, whereby I assume he ran it on the big WFC, there have been at least two more video's in which the car was *not* running. So, for all I know, there is *no* evidence that the injectors ever actually worked, but there are two video's that suggest he had at least a lot of trouble getting it working.
Is there any material like eye-witnesses based on which one can reasonably assume/conclude that the injectors actually worked?
If not, then IMHO we should concentrate on getting the big WFC replicated, because we know that has been shown to work and there is a solid theoretic explanation, based on a/o the work of Prof. Turtur, which explains how this works and how it is possible to extract energy out of the vacuum/aether/ZPE field/vacuum/whatever name you prefer.
lamare
« Reply #12, on September 4th, 2013, 12:25 AM »
Quote from Jeff Nading on April 12th, 2012, 02:54 PM
You're definitely not the only one who has had good results with "conditioned" SS pipes or plates. AFAIK, the best "replications" of Meyer's work (Ravi, Lawton, Cramton, Boyce) all used a conditioning process. And according to Boyce, the properties of what he calls a "catalytic layer" are very important:
http://free-energy-info.tuks.nl/Chapt10.html
Resistance to flow between the electrode and the electrolyte is an entirely different matter, and major improvements can be made in this area. After extensive testing, Bob Boyce discovered that a very considerable improvement can be made if a catalytic layer is developed on the active plate surface. Details of how this can be done are given later in the companion document "D9.pdf" as part of the description of Bob’s electrolyser.
Now whether or not this "conditioning" process is being done deliberately or not, there is *always* a dielectric layer present on SS. Depending on the salts present in the (tap)water and the specific alloy the stainless is made of, a certain number of oxides *do* grow on the anode, as in any normal electrolytic capacitor.
And the properties of the dielectric layer (material, thickness) determine the quality of the capacitor, both in terms of capacity and in terms of insulation properties of the dielectric.
IMHO, this layer is *the* most important design feature of the whole system, because a dielectric in polarized state is capable of converting energy from the ZPE field into electric field energy. And therefore IMHO we should concentrate on developing a process to grow a dielectric layer with the desired properties on either SS or aluminum in a controlled and predictable manner.
For stainless steel, a nickel hydroxide layer appears to be the most promising, but it also appears to be pretty challenging to get right, although literature is available, like the one from Becker et al:
http://www.tuks.nl/pdf/Reference_Material/Electrolytic_Caps_and_Super_Caps/
The chemical pasting of a mixture of active material on a support conductor is used to prepare the positive electrodes of alkaline batteries [4]. This kind of electrode is used in the batteries of mobile phones, mp3s, emergency lights, and electric vehicles. Nickel hydroxide should have a homogeneous particle size and bulk distribution. Two methods are commonly used to obtain this kind of nickel hydroxide: indirect chemical precipitation and direct chemical precipitation. In both cases nickel hydroxide is obtained as a powder that then must be properly prepared to build the electrodes.
For the manufacture of nickel hydroxide electrodes for use in high-performance batteries, such as nickel hydrogen batteries used as power source in space satellites, the impregnation technique used consists of the cathodic electrodeposition of sintered nickel plates. There are several variations of this technique such as (i) the Kandler process [5], which includes an electrochemical precipitation stage, working with a 0.3 M Ni (NO3 )2 solution and an initial pH between 3 and 4, which is adjusted with nitric acid, and (ii) the process developed by Pickett and Maloy [6], which applies the same principle, but using a nickel nitrate solution in alcohol, pH = 3.5. These are the impregnation processes that were taken as the basis to develop our technique for the preparation of nickel hydroxide electrodes for high discharge capacity and long service life. The different properties of the electrodes that make them superior are not yet well known in the literature [7–9].
« Reply #13, on September 4th, 2013, 02:30 AM »
I recall seeing in one of Meyer's photos that the tubes had an almost pitch black layer of sort, my immediate thought about that was that it was due to corona discharges, maybe I should try getting a new perspective here..........?
lamare
« Reply #14, on September 4th, 2013, 04:43 AM »
Quote from Lynx on September 4th, 2013, 02:30 AM
Very interesting:
http://en.wikipedia.org/wiki/Nickel%E2%80%93hydrogen_battery
A nickel–hydrogen battery (NiH2 or Ni–H2) is a rechargeable electrochemical power source based on nickel and hydrogen. It differs from a nickel–metal hydride (NIMH) battery by the use of hydrogen in gaseous form, stored in a pressurized cell at up to 1200 psi (82.7 bar) pressure.
NiH2 cells using 26% potassium hydroxide (KOH) as an electrolyte have shown a service life of 15 years or more at 80% depth of discharge (DOD).
The nickel-hydrogen battery combines the positive nickel electrode of a nickel-cadmium battery, and the negative electrode includes the catalyst and gas diffusion elements of a fuel cell. During discharge, hydrogen contained in the pressure vessel is oxidized into water while the nickel oxyhydroxide electrode is reduced to nickel hydroxide. Water is consumed at the nickel electrode and produced at the hydrogen electrode, so the concentration of the potassium hydroxide electrolyte does not change.
http://en.wikipedia.org/wiki/Nickel_hydroxide
Nickel(II) hydroxide Ni(OH)2 is an insoluble compound with strong redox properties and widespread industrial and laboratory applications. It most commonly is used in rechargeable battery electrodes, by oxidation to nickel(III) oxide-hydroxide.
http://en.wikipedia.org/wiki/Nickel%28III%29_oxide
Nickel(III) oxide (Ni2O3) has been referred to in the literature, but is not a well characterised compound. The substance black nickel oxide is sometimes described as being Ni2O3; however, the composition quoted by suppliers has a nickel content of around 77% by weight, whereas Ni2O3 would have 70.98% Ni by weight, and may be non-stoichiometric NiO.
There are references in the literature to traces of Ni2O3 on nickel surfaces, and as intermediates in nickel oxidation, e.g.
The related nickel oxide hydroxide (NiOOH) can be prepared by reaction of nickel(II) chloride with sodium hypochlorite; the sodium hypochlorite functions as an oxidizing agent:
4OH- + 2NiCl2 + NaClO ---> Na+ + H2O + 2NiOOH + 5Cl-
http://www.nickelinstitute.org/en/NiPERA/WorkplaceGuide/ToxicityOfNickelCompounds/OxidicNickel.aspx
Black nickel oxide and hydroxide are used in the production of electrodes for nickel-cadmium batteries utilized in domestic markets and also in large power units.
http://docs.sadrnezhaad.com/papers/416.pdf
Nickel oxide which is produced in this method is [...] accompanied by a color change from green to black.
lamare
« Reply #16, on September 4th, 2013, 11:17 AM »
Quote from Lynx on September 4th, 2013, 06:15 AM
I can't for the life of me find it now, maybe I was just daydreaming......?
It looked much like this,
http://open-source-energy.org/forum/attachment.php?aid=2362
I did some further investigations on the use of nickel hydroxide, but this is not suitable for our purposes:
http://open-source-energy.org/?tid=1168&pid=17448#pid17448
However, electropolished stainless steel might do the trick, which may turn out to be Stan's secret. I still have to investigate this further. See post linked above for more details.
lamare
« Reply #17, on September 4th, 2013, 01:07 PM »
Quote from lamare on September 4th, 2013, 11:17 AM
Yep, that seems to be the big trick. Made a new thread for that one:
http://open-source-energy.org/?tid=1372
