Covalent linkup of unlike atoms
Make a gas lattice... we now have a way using argon atoms with ions of nickle and cobalt; those ions will exhibit an electromagnetic field because their electrons spin in the same directions... argon is ideally used as it's a gas that is a lubricator, it does not like to transmit electrical energy and it also acts as an electromagnetic shunt... as a result we now expose the gas to an electromagnetic field and now you have electromagnetic alignments that extend beyond the nonmagnetic tube which transverses the coil to produce electrical energy... this gas, because of its interlocking between the covalent linkup, as well as its electromagnetic link up, gives us the ability now to move the straight magnetic flux lines in the closed-loop tubular pathway by which those magnetic links remain in tact and in the correct position...
See: https://www.youtube.com/watch?v=5C-9uYhKo0I
N.B. We're now doing some unique things on osculating the magnetic fields in order to achieve the maximum efficiency of these generators...
EPG Photon Drive Gas Accelerator
Now we are confronted with accelerating the process to the star wars level... We are now injecting laser energy into the gas which in turn allows the electrons of the gas to move further away from its nucleus and therefore increase its spin... and under the electromagnetic theory of magnetism that whenever an electrical charged particle passes through an electrostatic field something's got to happen in the law of physics and what takes place is an increase in electromagnetic field... and therefore we are now moving the magnetic field close to the speed of light because the nonmagnetic tube is now being converted into a light guide and the laser energy is no longer being dissipated outside of the light guide; it's being reflected, much like that of fiber optics... if we want to compound the electromagnetic field we simply will hit the gas at a burst of 10 watts of laser energy and as the laser energy passes through the gas and goes back to the original point we now allow the laser to lase again and we are now superimposing more laser energy on the process so, as a result, we are now moving a greater intensity magnetic field and we go around and do the same thing again and in a very short period of time you are now moving an electromagnetic field of tremendous high intense energy...
...this technology allows us to amplify the electromagnetic field, at many magnitudes, without increasing mass so therefore gave us the ability to overcome the limits of the prior start of the art.
...the laser energy is absorbed by the nucleus causing the electrons to go to a higher energy state and when that occurs, as it migrates from the nucleus, the electron spin increases, and when it increases you are now increasing its electromagnetic fields.
Enjoy... :)
All the best
Ethos Pete...
Enjoy... :)
All the best
Ethos Pete...
