Hey,Quote from hydrofuelincanada on April 4th, 2012, 10:39 AM I have been asking him for a long time now, not just on this site.
We all should know by now that adjusting the burn rate to that of gasoline, absolutely no engine modifications are necessary.
Sorry for not replying. I also have seen some of your questions about your your torch. I have not seen anything you have done. I need to get on your YouTube channel and take a look. I have been a little bit overwhelmed with life lately. My upmost apology for not answering your questions.
The only reason I would want to modify the engine timing is to just do tests. I have tried a lot of different mixtures with hydrogen ambient air and recycled exhaust gases. I've even almost completely shut off the exhaust and it still runs. but it has not run like it normally would on gasoline. So I wanted to be able to play with timing to see what was easiest. It's very simple to a just timing on a car. So it options should be there. Even if you look at Stan's GM S unit he is able to adjust the timing as well as everything else. So I think that we should be able to adjust the timing even though we're trying to adjust the burn rate of hydrogen it's a different medium and I believe that timing will need to be adjusted to get maximum performance
I've already proven that you can run hydrogen into an engine with no modifications and make it work. But unfortunately I haven't got the same horsepower out of it.
I'm not the first person to do this but just from experience on my own tests I think that timing needs to be adjusted.
If you would please post your YouTube channel link here. I don't think I have seen any of your work and I think I should. Sounds like you've done a bunch of research and I definitely need to check it out.
I haven't answered hardly anyone's questions on YouTube lately. I've had a hard time getting on there and responding. Anytime I'm on a computer I can't get to YouTube. :) (at work)
Also on the note of water ruining the engine. Once the engine warms up the water will evaporate. If you're using straight hydrogen and oxygen I can see it being a slight problem. But you're always going to be introducing some ambient air and in this case recycled exhaust gases as well. This will minimize the amount of water in the engine. If you take a look in this video
https://www.youtube.com/watch?v=wY7OHAqGdn8&feature=youtube_gdata_player
You will see that the engine was spitting out water when it was cold. At the end of the video you will see that once it warms up there was no more water in the system. But I do not adjust anything it just wants up enough I think to the evaporate the water.
I was going through some notes and thought you may be interested in something about magnets.
Some time ago I found on an italian forum where someone in the Northern Hemisphere used the polarity of North on their Fuel line(petrol), South on the Air intake.
So i suggest to help these be attracted to each other in the combustion chamber when adding HHO, add a magnet to the hho line (s) South. Put the magnets on plastic/rubber pipes only, give the length (say 30 to 60mm)of the magnet enough to have a useful time for polarisation, maybe that might be of use.?
