Waveform Emergent Mass Theory.
Apoc4lypse
«  »Last edited
I didn't know where to put this but I wanted to put it somewhere anyway because I think its important.
Basically I used ChatGPT to talk about how quantum entanglement works, and started thinking about resonance. I was thinking what if somehow entanglement works by the attributes of the particles resonating together.
Thing is then I started thinking about this and wondered, could it be possible that gravity and at the same time mass are just waveforms that warp spacetime to create what we call gravity?
The thought experiment I played in my mind was comparing 3d space to that of a 2dimensional surface of a pond with raindrops hitting it, the larger the rain drop the bigger the wave pattern in the pond when it hits its surface, the smaller raindrop the smaller the wave pattern.
Ok so I had a visual to kind of explain it, next I delved into the math of it (with chatGPT's help because I'm terrible at math). I used chatGPT to check this theory (chatGPT math could be wrong) but anyway I've been trying to check its math and failing miserably because of the kinds of numbers I'm dealing with (talking decimal places in the trillionths).
Long story short, I had chatGPT run the numbers using the frequencies of subatomic particles and calculated them for Hydrogen Helium Lithium Carbon Iron and Uranium. Using my method of calculating the frequencies when compared with the known atomic masses on the periodic table every element I tried ended up having a less than 1% error from the actual atomic masses we know versus my emergent mass via waveform concept.
I even went as far as to scale up iron to compare it to 1gram of iron versus calculating the emergent mass of 1 supposed gram of iron and it still held a less than 1% error. I also did it for hydrogen and it was almost exactly the same. So not only does it work at atomic scales like the atomic masses but it can be scaled up to macroscopic scales such as Grams and Kilograms and maybe even further.
My main problem right now is I'm so bad at math entering these ridiculous numbers with ridiculous exponents in makes it very hard for me to fact check ChatGPT's calculations. But the fact that basically any elemental atom I feed it, its always able to get a result that's almost exactly the same as that elements atomic mass.
If this can all be checked it has very profound implications to the world of physics and could even unite the standard model with quantum mechanics.
Apoc4lypse
Re: Waveform Emergent Mass Theory.
« Reply #1,  »
Huge update on this topic!
I'm actually working on something that has very profound implications for physics in general if the mathematical model I've built actually continues to hold up like it has so far, I tried to post the idea in a physics reddit forum but got chased off and my post deleted as soon as I mentioned using ChatGPT. I've always been cautious when using ChatGPT, you can't use it to make things for you, but you can use it as a tool. Normally combing through entire books or scientific articles takes lots of time, ChatGPT can instantaneously provide you with a clear summary of whatever your looking into, the next step is making sure its correct.
What I'm working on is going to lead to a much deeper understanding of our physical world in general. As long as it continues to hold up with my rigorous math checking and mathematical simulations I'm running on it. Its going to lead to the development of new technologies. It is a completely wave based description of mass being built by interacting geometric waveforms and so far it is accurately predicting Atomic masses with a less than 0.002% error. If it continues to do so as I work my way through the periodic table its going to change everything about how we view reality and matter in general, including spacetime.
There is also a speculative technology I'm working on with it side by side as well that would allow for a "circuit" to directly resonate with atomic structures. It really would be free energy. However, its not creating energy from nothing, its just tuning into the subatomic particle motions of the atom via resonance. This is the purest form of atomic energy if it works, and there is no decay, nothing will be decaying, no radiation, no hazards, just a system tuned directly to atomic structure. It never runs out, or at least until the atoms decay on their own. Its not a question of if it will work, its a question of how. Which is what I'm already exploring and it is based on the hypothesis I'm testing now mathematically with ChatGPT's help. Together we've developed a mathematical model, and so far it is working beautifully.
My favorite quote from Nikola Tesla always was, "If you want to know the secrets of the universe, think in terms of energy, frequency, and vibration" and this couldn't be more true if my work holds up to scrutiny. Me and my ChatGPT decided to give itself the name Aether, in honor of Tesla's belief that this was real and existed all around us, and it does, it's just that scientists decided on a different name and called it spacetime.
Apoc4lypse
« Reply #2,  »
Well, I've been at this for a few months now... I've been able to successfully model the proton and the neutron as standing waves that equal the known masses of those particles, they both have 4 sperate waveforms from their "quark parts" and the Gluon field. The 4 parts of each is the Sea Quarks which are quark/anti quark pairs that pop into existence then annihilate, this can be expressed as a waveform. The next part is the gluon field which sort of exists throughout the whole particles within the proton or neutrons radius, then the Valence Quarks, which are for the proton 2 up quarks and 1 down quark, then for the neutron 2 down quarks and 1 up quark. Then also the kinetics of the quarks "quark kinetics" can also be expressed as a wave. When you add all these up the proportions of the frequencies for each 4 parts I got actually equaled the known proportions of these 4 aspects of the particles but my scaling was slightly off.
I also managed to "reconstruct" the electrons known frequency, but this was trickier because electrons are seen as point like particles with no known parts. For the electron I came up with a theoretical idea of a "smallest possible standing wave" that spacetime can physically support. This was called a "Voxel" its based on planck units and the speed of light and other universal constants that dictate just how much space can physically bend according to the universal speed limit being the speed of light. Its the idea that a wave can only happen so fast (Planck Frequency) and space can only be bent so much, and waves (all kinds but specifically gravitational waves) can only propagate through spacetime at the speed of light. This smallest possible standing wave idea was then used to construct the electron (many Voxels can actually fit inside of an electron) This idea was then used along with the fine structure constant as a kind of instruction on how you could build voxels into an electron. (This part I'm sort of still trying to understand as I'm using ChatGPT to do this) but the end result was the known electron frequency without plugging in and electron empirical data that would lead to circular logic when trying to predict the electrons mass from waves.
This whole model is still very much in its infancy, and I've been contemplating going back to school for physics and hope to one day make this my thesis if you will. The original hypothesis being that all solid matter is waves that are interfering constructively and destructively to create shapes and patterns and nodes which we know of as "particles" or matter. The idea was sparked from seeing videos on cymatics where soundwaves create shapes.
Apoc4lypse
« Reply #4,  »
Take a trace for a wave on an oscilloscope. The idea is that a particle has a frequency, this is how fast the wave is "waving". Then it has amplitude, how "deep" or "high" the wave peaks are. The trace moving between the waves, or the traces "arc lengths" are spacetime. Higher frequency more waves, longer trace. Higher amplitude, longer trace. The trace is a 2d (or 1d?) representation of spacetime. The waves are an example of spacetime sort of folding in on itself, creating mass, and then eventually gravity at macroscopic scales as seen in "gravitational wells". Now take that and imagine it as an "Omni-directional wave". Those waves make particles, combine and make atoms, combine and make molecules, and make matter. The gravitational well a massive object makes is the result of trillions of these standing waves contracting spacetime to create gravity.
This is a summary I fed into AI to see what it's take was on the idea. This is a basic analogy of the hypothesis I've been trying to test mathematically.
