Invitation to Join Open Research on RWG for Wireless Energy Harvester Circuit
Hello RWG Research Members,
We are embarking on an exciting open research project, and we invite you to participate, collaborate, and innovate on a cutting-edge Wireless Energy Harvesting System. This project revolves around a rectenna (rectifying antenna) and power conditioning circuitry that captures and converts ambient electromagnetic energy into usable electricity. Whether you're passionate about renewable energy, wireless power transfer, or electronics, this project has incredible potential, and we need your expertise to help test, improve, and optimize the design.
Here’s a detailed breakdown of the system we're working on:
1. Rectenna (Rectifying Antenna) Energy Harvester
The rectenna is the heart of our energy harvesting setup. Its function is to capture electromagnetic radiation (such as RF energy, Wi-Fi signals, or other ambient energy sources) and convert it into direct current (DC) electricity. This conversion occurs through:
Design to be mass production up to 1000 rectennas could be series wired and joined together to make a large panel.
This also could Extract from Liquid such as salt water. Or Nano Bubble Water Fuel.
Diodes (1N34, 1N4148): These components rectify the alternating current (AC) signal gathered by the antenna, turning it into DC electricity. Diodes allow current to pass in only one direction, ensuring efficient conversion.
Capacitors: These store energy temporarily and help smooth the DC output, stabilizing it and making it ready for further use.
Array Structure: The rectenna consists of multiple diode-capacitor pairs arranged in a grid to maximize energy collection and improve efficiency. Notes we can put a Additionally Large Aluminum back plate on rectenna flat plate, or or a spiral Lilly impeller copper tube in top of a pyramid to gather power both work find and are just ways to add electron gain. shape
2. Power Receiving Board
Once the rectenna collects energy, it’s passed to the power receiving board. Here, the system performs additional voltage regulation, increasing the energy's utility:
Impedance Matching Circuit: To ensure that maximum power is transferred from the rectenna to the rest of the circuit, the impedance matching circuit minimizes energy loss.
Dickson Voltage Doubler: This clever circuit uses a combination of capacitors and diodes to increase the voltage, making the harvested energy more usable for various applications.
Capacitors and Diodes: These components stabilize the voltage and protect the system from surges and fluctuations, ensuring safe and consistent power delivery.
3. SMA Connector
The SMA (SubMiniature version A) connector provides a high-efficiency link between the rectenna and the power board, allowing the signal to be transferred with minimal interference or loss. It ensures reliable connectivity for high-frequency signals, making it ideal for energy harvesting systems.
4. Buck Converter
A DC-to-DC buck converter takes the rectified energy and steps down the voltage to a more usable level. Whether you're powering a small electronic device or charging a battery, the buck converter allows you to adjust the voltage from the incoming 12V DC down to a range between 1.25V and 48V, making it adaptable to a variety of applications.
5. ZVS (Zero Voltage Switching) or Stanley Meyer Circuit
The final output from the power board can drive a ZVS circuit—an efficient system for powering inductive loads or enabling wireless power transfer. The Stanley Meyer circuit can also be employed for hydrogen voltrolysis, breaking water molecules into hydrogen and oxygen using high-frequency pulses.
6. Diodes, Capacitors, and Other Parts in the Circuit
Diodes ensure the smooth flow of energy, preventing reverse current, which could otherwise damage the circuit.
Capacitors store and stabilize energy, allowing the system to quickly release charge when needed.
Zener Diodes help regulate the output voltage, preventing over-voltage conditions that could damage sensitive electronics.
7. DC Output
The system produces a stable DC output that can be used to drive other circuits, charge batteries, or store in capacitors. The versatility of this system makes it suitable for many applications, from powering electronics to wireless power transmission and renewable energy storage.
Summary of System Operation:
Energy is captured by the rectenna and converted from AC to DC via diodes.
The DC signal is stabilized and processed by the power receiving board, which steps up the voltage if necessary using the Dickson voltage doubler.
The SMA connector links the two boards, ensuring efficient energy transfer.
A buck converter steps the voltage down to the appropriate level for further use.
The system outputs a clean, stable DC current ready for use in driving loads or powering other systems, such as a ZVS circuit or Stanley Meyer voltrolysis setup.
Your Skills.:
We believe this system holds vast potential, and we want you to help take it to the next level! Whether you're an electronics enthusiast, researcher, or engineer, we welcome you to join this open-source research project. Together, we can experiment, improve, and optimize the design to make it more efficient, practical, and scalable.
Here’s how you can get involved:
Build and test the circuit: Use the provided schematic and try building it yourself. Test its efficiency, tweak components, and provide feedback on what works and what can be improved.
Suggest improvements: Got ideas for more efficient diodes, capacitors, or circuit designs? Share your thoughts, and let’s collaborate!
Share your results: Upload your test data, videos, and images to the RWG platform, so others can learn from your findings and build on them.
Let’s innovate together and push the boundaries of what’s possible with wireless energy harvesting!
Join the conversation, share your insights, and be part of this cutting-edge project. We look forward to seeing your contributions!
Best regards,
Daniel Donatelli
Secure Supplies Team
3. SMA Connector
4. Buck Converter
7. DC Output
Your Skills.:
Best regards,
Daniel Donatelli
