Stanley Meyer's “ISOLATED ELECTRICAL GROUND
https://youtu.be/BUq-w8pxVxw?si=sxpejzdSe24xEc94
 Stanley Meyer's “ISOLATED ELECTRICAL GROUND” concept
Valentin Petkov /valyonpz/
4.21K subscribers
585 views  May 5, 2024
Stanley Meyer's “ISOLATED ELECTRICAL GROUND” concept.
VIC “ISOLATED ELECTRICAL GROUND” terminal, must be connected to overall "water bath", in the Water cell setup:
https://drive.google.com/file/d/1FGnSyRAtl-5IWWMU8LnSvLxuvyqnnd4R/view
https://drive.google.com/file/d/16NYEfBji8Om2pkLJjqCqTNBaXXFRTTXN/view
Note, that the "water cell resonance" is not ordinary "electrical resonance"! It is, as Stan Meyer calls it - "resonant condition". At "resonant condition", at a certain frequency, to the Cell`s electrodes is directed two, 180 degrees out of phase signals, with oposite polarity.
Note that, when to Outer electrde is apply maximal positive voltage, to Inner electrode is apply minimal negative voltage. Thus, the differential voltage between the electrodes, remains constant:
https://drive.google.com/file/d/1Q212nddI8pAPRCnRygPK-gaCgcCXLsP-/view
About Stanley Meyer's “ISOLATED ELECTRICAL GROUND”, please, read carefully: "Memo WFC 427", everything is described in detail :-)
Stanley Meyer`s Memo WFC 420-421-422DA-423DA-424-425-426-427-428-429-430 (Copy Unlocked):
https://drive.google.com/file/d/1D33NqNY1AZEdQnu6IrTfFavwPIIRP3qV/view
Stephen Meyer`s Patent US 2005/0246059 A1:
https://patents.google.com/patent/US20050246059
Andrija Puharich`s Patent US4394230A:
https://patents.google.com/patent/US4394230
Stanley Meyer's Patent US4936961A:
https://patents.google.com/patent/US4936961
Stanley Meyer's Patent WO 92/07861:
http://www.rexresearch.com/meyerhy/wo92.htm
Stanley Meyer's Patent US5149407A:
https://patents.google.com/patent/US5149407A/en
My Circuit diagram:
https://drive.google.com/file/d/1Yx39CnWs0IgL0O_b2ayKAtSRXRjI42my/view
Re: Stanley Meyer's “ISOLATED ELECTRICAL GROUND
« Reply #1,  »
  It is Vital to note that stan moved to a plastic tank and  was able to stop the ground of the bubble the water and the metal surfaces thus keeping bubbles in suspension for lon periods so once gas made nano bubble water made it can be held as de stabilized gtnt for long periods and than send through a positive ground vehicles fuel system for ignition  those studied in the art will know this make more force than heat and is non Carnot cycle so there is more to it beyond just making the gas it is about making nano bubble water and and holding it in a missing electron state with out be able to ground back electrons , it is lso important to note if a variac is between ground and cell you can tune the rate of repowering or grounding just like tesla did   many people now use this for making power and fuels.  DD
« Reply #2,  »Last edited
i add this for your  vision
remember cells always in series pairs to balance coils resistance
wire them like a solar panel cells are wire with by pass diode inces 1 pars fails total cell keeps going and does not
turn off like when christmass lights fail 1 globle closes all lights when in series if you wired correctly you get alot of gas
