How to the Resonance frequency, affects the Voltage on the Water Fuel Cell
By PetKov
https://youtu.be/fhRCsk_iRNE?si=i0UGRl3Th5ss8bTh
Valentin Petkov /valyonpz/
12 May 2024
In this case, I use Stanley Meyer`s VIC Multi-coil Spool Assembly:
https://drive.google.com/file/d/1xB6ijhKZ1u-wNnXRA81Zgi2b81i6QEQq/view
https://drive.google.com/file/d/1KYWd9mMpp9VK5S8Wo-5tPU1_m7bjZfys/view
Very Important! The all coils, must be placed on "common" core:
Electromagnetic Interaction: The resultant tri-coil configuration (Inductance core 53 - choke coils 56/62 - primary coil 26 - secondary coil 52), now, allows magnetic field coupling (71a xxx 71n) to pass through both resonant-coils (56/62) and secondary coil (52) simultaneously when primary coil (26) is pulsed energized by way of incoming pulse-train (46a xxx 46n).
Here is my "working" setup:
https://drive.google.com/file/d/1GrPe3OfkQAA4Xm51Ooedeuj-mInLepNq/view
https://drive.google.com/file/d/1GZWizzAo4vcvsDqtfnmFo7s5JJ8MgFjH/view
My short video, here is only 150 Volts to the Water Cell (Meyer describes one Cell`s workong voltage - 650 volts to 1000 volts !!!!!):
https://drive.google.com/file/d/1Kq_q_NXp0F88kcbm1mZie_KhuzhEZkp7/view
https://drive.google.com/file/d/1FgrVSnh1KEhvEF522dfxn-mslR_Bej4k/view
https://drive.google.com/file/d/1a3SU6x14fnba6xHrGPCAq_2ANkzRffH2/view
My Oscilloscope screenshots:
https://drive.google.com/file/d/1VtV_L4UDaKzUzy2pMoje_zc4hFX5CiUJ/view
Here is "correct" VIC Multi-coil Spool Assembly coils orientation. If the coils connection is different, no "resonant sensitive voltage effect" is obtained:
https://drive.google.com/file/d/1lBFqzcB59NXZW-Hw_9GYZehWQDU42N9E/view
As you can see, now the Positive Wave-guide is 364 Vpp and Negative Wave-guide is 384 Vpp. If you want to "equalize" the opposite potential to Cell`s terminals, to minimize current leakage through the Water Cell, you must "fine tune" the Anode or the Cathode inductor, by increasing it`s nimber of turns, as is shown by Stanley Meyers:
https://drive.google.com/file/d/1lBFq...
Stanley Meyer`s readings, described in Memo WFC 425:
Resonant Choke Coils - 0.004 Ga – 0,10 mm.
Primary Coil - 0.030 Ga – 0,8 mm.
Secondary pickup coil - 0.002 Ga – 0,05 mm.
Stanley Meyer`s Memo WFC 420-421-422DA-423DA-424-425-426-427-428-429-430 (Copy Unlocked):
https://drive.google.com/file/d/1D33NqNY1AZEdQnu6IrTfFavwPIIRP3qV/view
Stanley Meyer`s Patent WO 92-07861:
https://drive.google.com/file/d/1q3__OhysJCw9F-m6rx8C4zy2bj5rREzw/view
Stanley Meyer`s Patent US4936961A:
https://patents.google.com/patent/US4936961A/en
By PetKov
12 May 2024
