[Here's a re-post of a 2021 topic @ my workbench, so as to have the content linkable for non-members]
May 13th, 2021, 03:19 PM
I took a break from 'tesla coil stuff' to finish a stale project from last autumn - a backup lithium-ion battery bank, housed in a military surplus 50-cal Ammo Crate (steel, waterproof, fireproof). Here, I want to describe the build thoroughly enough that one might get a good idea of how to reproduce it (and to help cement my own understanding of the hardware as I summarize everything).
For this project, I chose a hardware setup featuring modular/stackable PCB's which contain the batteries and battery management system (BMS) chips - 7 cells in series (7s), for nominal "24 Volt" battery bank.
To house it all, I opted for the 'Ammo Can' setup, with 70 lithium ion cells (10x 7S pcb's). Generally, you can use these same PCB's to make a "DIY PowerWall" as big or as small as you want, if you keep stacking 7s Modules with enough BMS's mixed in. Wiring is pretty clean, mostly just ribbon cables and brass standoffs serving as buss bars. Cool stuff!
I'll be referencing some open-source PCB designs, which are NOT my own original PCB designs; the inspiration and hardware for this project all came from jag35.com (jehu garcia on YouTube), see included links. I appreciate that he sells the kits, yet also allows open-source access to his designs for those interested. I have attached his gerber files (free from his website) for the PCB's (battery holders and BMS, with parts lists in links below).
Here's link to page where I purchased mine from, which contains further links to parts etc (I'll put in a screenshot pic in case link goes bad).
https://jag35.com/products/18650-battery-module-diy-pcb-kit <---- these are the ones I purchased, good description
https://jag35.com/products/24v-ammo-can-battery-kit <--- I didn't use this exact kit, but it has a good parts list
Here's the walkthrough vid I roughly followed:
https://www.youtube.com/watch?v=bAB5A_ZR5M0
*The original plan was for this 24v (nominal) battery bank to be part of a 'solar generator', connected with 24V A/C Inverter & two 100W flexible solar panels, hanging inside a window inside my 2nd-floor apartment in Austin, Texas. The whole 'solar panels in window' part didn't work out, but the battery works great! With the AC inverter, I have working power outlets for outdoor use or in case of emergency.
