Slowly my radiant coil capacitor project comes to a conclusion.
And I realize, I can continue my research on a different path.
Instead of using a coil voltage impulse, which has dual polarity displacement currents
I now need to develop a solid state capacitor current impulse.
Since SiC Mosfets nowadays have high voltage capabilities, and low on resistance, my first tests will be, to see how small a capacitor needs to be to be able to discharge it through a MOSFET.
The high currents will be short but intense, thus the MOSFET will need active cooling, I wonder if liquid cooling would work.
The capacitor needs to be small, so it doesn't instantly fry the MOSFET.
I will also need a high voltage source, but that seems easy.
and, I need a plate(coil) to produce the displacement current. from the high dV/dt
A new circuit needs to be formed, which uses this unidirectional displacement to amplify resonance energy.
to create an inflow of energy into a vacuum of energy.
